ThrottleAbuse
Seems like the tylt you are using is charging at a similar rate according to the screen shots. The tylt doesn't use much power 12v/750 mA so it's really just a bad design because it's a proprietary plug. I don't know if I would really call the Itian a knock off just because it has the same form factor. It's not like the makers of the tylt are the inventors of wireless charging.
