So, I had my phone in my pocket during dinner and checked it out later aftwrward, and the Android system was consuming most of the battery. Anyone know of any reason why?
Do you have sync on?
That might be the main culprit.
Posted via my Galaxy S5
Just pull down your quick setting at the top of the screen and see if sync is lit up or not.
With sync off you'll have to check your email manually, as it won't push through anymore. But you can turn it on while the phone is charging or something and let it back up things to your Google account.
I'll bet it kept turning on in your pocket. Just a guess. I've had that a few times.
I'm just going on the fact that your screen is 29% with 3.5 hours of on time.
Okay, so email. What about other social media?
I don't really know what you're expecting. The phone is only coming on when you have the screen on, I don't think it's a sync "issue." Being down to 30% after 8 hours of pretty heavy use and 3.5 hours of screen time seems normal. If you'll look at your graph, you'll see the battery barely drains when you aren't actually using the phone.
No need to apolgize, I just wanted to point out that your battery life seems pretty solid from my experience and that I don't think turning off sync will do you much good.
