03-24-2017 04:18 PM
28 12
tools
  1. jl1959's Avatar
    I just had same thing on my note 5,using Gboard.Go to
    >language input
    >Gboard.
    >dictionary then delete learned words.
    It makes you type in a number that's provided/that's it!
    01-05-2017 12:51 PM
  2. Sailor Will's Avatar
    Thanks mate. I had the same problem but your method cleared the problem on my J5(6). All I need to do now is never forget it!
    02-25-2017 11:03 AM
  3. SionLeGard's Avatar
    I figured it out for chrome and maybe all of them. Basicly you want to go to the three dots, then click settings. Then you will want to click on your profile sync settings. Then click sync. A menu will pop up, then scroll down to manage synced data. Then a web page will pop up. At the bottom of the page you want to press the reset sync and it will delete those unwanted tabs from incognito and google. It was annoying but thank God I was able to figure it out.
    03-24-2017 04:18 PM
28 12
  1. Galaxy S3 sync issue with Outlook
    By misterfrostie in forum Samsung Galaxy S3
    Last Post: 09-04-2014, 03:25 AM
  2. Replies: 7
    Last Post: 09-03-2014, 05:03 PM
  3. Samsung Galaxy S4 root problem, Need help :(
    Last Post: 09-03-2014, 03:09 AM
  4. whtsapp is not working on my s4
    Last Post: 09-03-2014, 02:02 AM
  5. whtsapp is not working on my s4
