Hello all
I had tried to make a call on my Galaxy S5 (AT&T). As soon as I would try to make the call, the prompt on the screen would be stuck on "Call". I did go to Ultra Power Saving mode and the call worked that way. I had tried the hard reboot (holding the volume up, power and home keys) and did a cache clear partition. But on regular mode the call is stuck and won't get through.
Anything else I need to do before the infamous "factory reset?"
Thanks
Thanks
