Battery Drain
Dominic Lynch
12
Hey I recently encountered a weird android process's glitch it has used 44 percent of my battery while my screen has only used 21 percent I use my phone quite hard most of the time any help ill be grateful also ill provide screen caps (I use nova launcher prime )
Gekko
Banned
May 15, 2010
5,263
123
you have almost 18 hours of usage and you are at 46%. don't worry about it. the other percentages are not % of battery but % of total usage.
PsychDoc
1,402
7
38
Typical battery life will give you 14-24 hours of total usage and 4 - 5 hours of screen-on time. Anything more than this should be considered a fluke.
bassplayrguy
Trusted Member
May 3, 2013
2,945
8
38
Are you really complaining about this? This is better battery life than anything you are going to find. You be bragging about it.
RemusGhostofRome
