The end bit of my headphone got stuck in it and I tried getting it out with a toothpick and superglue (WHICH did not work?!). I don't know if I made it worse with the super glue. PLEASE HELP ME!!! :'(
Printable View
Sounds like you need to replace the headphone jack. Not good because the S5 is very difficult to take apart without damaging. The S4 was very easy to take apart and change parts in. I replaced the charge port in my sister's S4 and it was very easy.
The S5 has two mid frames and the innards are sandwiched between the display and a special compartment. Not good news for you, I'm afraid.
