Hi, is it normal for a 4 day old GS5 (SM-G900H) to creak when you apply a bit of pressure on the lower back part of the phone? Mine makes a pretty audible creak/click sound every time I lightly press on the lower part of the battery door. After a bit of investigation, it seems like the battery is slightly loose, as in it pops out quite easily when the battery door is removed. Is this normal or should I be concerned?
Thanks.
Thanks.
