1. ronin425's Avatar
    i have a real hard time connecting the battery charger cable jack to the S5. is there a trick to this or what. i don't want to end up damaging the port or any other part of the S5. any feedback welcome......
    11-20-2014 03:02 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does it seem really tight? Or is it just hard to line things up, with such a small plug? Finicky microUSB ports and plugs is one of the main reasons why wireless charging is such a nice option.
    11-20-2014 03:19 PM
  3. Rukbat's Avatar
    Look at the end of the plug. Look into the port on the phone. You'll see that one side is longer than the other on each. Make sure you aren't trying to put the plug in upside down.
    I agree with wireless charging. (And wireless data transfer and anything else you can do without using the microUSB port. It was about the worst connector the industry could have chosen.)
    11-20-2014 03:26 PM
  4. mary beth hale's Avatar
    If you're talking about the 3.0 charger that comes with the phone then, yes, it is a pain to insert. Seems to charge my S5 very quickly though, so I continue using it. You can use a regular 2.0 charger if too much of a hassle.
    11-20-2014 05:33 PM
  1. Strange Battery Usage Stats Lollipop
    By belodion in forum Google Nexus 5
    Last Post: 09-09-2016, 04:52 AM
  2. Last user to get Lollipop OTA update on Nexus 5
    By elusive11 in forum Legacy Android & Other OS's
    Last Post: 11-21-2014, 10:45 AM
  3. Why do I need to enter a PIN to answer calls or dismiss alarms?
    By irwinr in forum Legacy Android & Other OS's
    Last Post: 11-21-2014, 01:29 AM
  4. Can't transfer data from phone with broken screen
    By Elina Filipova in forum Samsung Galaxy S5
    Last Post: 11-20-2014, 11:52 PM
  5. Why have I lost internet connection?
    By georgewf in forum Ask a Question
    Last Post: 11-20-2014, 01:48 PM
