Hi All,
I was wondering if someone can help me. I am having a bizarre problem on my Galaxy S5, which so far has stumped Verizon, Samsung and Time Warner Cable Tech Supports.
For some reason, when I'm connected to my home Wifi network, certain apps run very slow. Basically, if you open an app like Facebook, Instagram, or the Google Play Store, a lot of the icons, pictures and thumbnails all show up gray, and either don't come up at all, or take forever to load. As soon as I turn Wifi off and switch over to 4G, they all pop up almost immediately. I've also noticed this problem on Google Now. You tap the microphone, say a command and it gets stuck on "Recognizing..." for a long time, and quite often comes up with "Can't reach Google at the moment." Again, it's only certain apps. Other apps like my web browser app don't seem to be affected.
This doesn't make sense to me, because I also have a laptop and my girlfriend's Galaxy S3 connected to my Wifi network and they don't have this problem. I've even busted out my old LG Spectrum 2 and sure enough, these apps load up lightning quick on it. I've done an internet speed test on my S5. On my Wifi I get a 19ms ping, download speeds of 18 MB/s and uploads pushing 2 MB/s. When I'm on 4G, the ping is 40ms, and the speeds are only 6MB/s and 0.7MB/s respectively, so the Wifi theoretically should be way faster.
I spent over an hour on the phone with Verizon and Samsung Tech Support, and after trying a ton of different things, including a Factory Reset, they determined it was probably the device. Since I'm under warranty, they sent me another one. I got it yesterday and tried it...yep, same problem.
Just out of curiosity, I tried it on the Wifi at my workplace. Wouldn't you know it, the problem isn't there. But, I don't understand what could be wrong with my home Wifi. I've got Road Runner Turbo internet from Time Warner w/download speeds up to 20MB/s. I've also got a really good modem/router that cost several hundred dollars. And, like I said the problem doesn't seem to happen on other devices.
I've searched the internet and have found almost nothing on this. Does anyone know of something I can try? Here's everything I've tried so far:
Here's my hardware details:
Thanks so much in advance!
- "Forgetting" my Wifi Network and Reconnecting
- Resetting the Modem/Router
- Clearing Data and Cache on Affected Apps
- Phone Factory Reset
- Trying with another Galaxy S5
- Switching from DHCP to Static Connection on Phone
- Switching DNS to Google's Addresses on Phone (8.8.8.8 and 8.8.4.4)
- Tinkering with the Modem/Router Security Settings and even Disabling Security
- Changing the Router Bandwidth Settings
- Changing my Router's Broadcast Channel - Have Tried Several Different Ones
- Calling my ISP and Upgrading to a Higher Bandwidth/Speed
- Phone - Verizon Galaxy S5, Unrooted, Running Stock Kitkat 4.4.4
- ISP - Time Warner Cable, Road Runner Turbo
- Modem/Router - Motorola/Arris SBG6782-AC
