Hello,
I have a Samsung original wireless charger pad mini and cover, and I've noticed that if I place the phone over the night it charges till 100% and then starts draining the battery and when I woke up I have less than 90% of battery on my phone.
I also get from time to time the information to check if the back cover is correctly placed. I do not know if this also happen with the stock one, cause I used only short time before getting wireless charger one...
Is this normal?
Can I do something to change that?
Also I had a S2 before and I think think the photos wore better then with S5, it got some blur images, and does not look very good when you zoom-in...
Thanks for any tip,
ZJ
11-27-2014 01:48 PM
