I used to have the pro version of
https://forums.androidcentral.com/e?...token=HS88yB7x on my S3, I didn't decide to put it on my S5 because I wasn't using it much. It worked well, but I turned off a lot of stuff to save battery life. Amazon has the pro version on sale sometimes, that's when I bought the Pro. I had it programmed to turn off my ringer when it connected to my car and load my MP3 app, then at work it would go into vibrate. When I was within 50 yards of my home it was programmed to turn my ringer volume and all other volumes back up to max. However, it is very customizable for any of your needs.
