1. StuLip's Avatar
    Suddenly, only one channel works with headphones. Tried several pairs that work well on other devices. Any advice on how to fix problem?
    01-01-2015 10:03 AM
  2. TheMonkeyDonkey's Avatar
    Does it not work at all? My right channel has very quiet distorted audio.
    01-01-2015 11:46 AM
  3. StuLip's Avatar
    TheMonkeyDonkey, that's it exactly. One channel clear, good sound. Other static, crackling noise with nearly no sound of music.
    01-01-2015 12:06 PM
  4. TheMonkeyDonkey's Avatar
    I've disabled the equalizer, and I don't have this problem with bluetooyh so it looks like this is a hardware problem...
    Something interesting I've just noticed: when I move the sound balance setting (in the accessibility settings) all the way to the left I still get some distorted sound coming out of the right earbud, which is odd because all the sound should be going to the left earbud at that point.
    01-01-2015 12:23 PM
  5. StuLip's Avatar
    When I changed equilizer setting, is when it started. I went back and pressed reset but no change. Am I doing it correctly?
    01-01-2015 03:40 PM
  6. TheMonkeyDonkey's Avatar
    Have you had any luck finding what the problem is?
    I don't think the equaliser is the problem as I've moved everything back to default settings and it didn't make a difference.
    I've noticed that the static doesn't stop immediately when I stop playing music, it stops about 10 seconds afterwards. The loudness of the static noise is also independent of the music volume. Actually, even if the volume is turned all the way down, there's still static as long as music is playing. I don't think a faulty headphone jack or something like that could cause this... Could it be a faulty DAC?
    I've tried returning my phone but I was told Samsung doesn't offer any warranty... strange.
    01-05-2015 08:52 AM
  7. Rick Esenwine's Avatar
    The S5 is warranted for 1 year through the manufacturer. My wife just had hers (7 months old) replaced through Verizon. All we paid for was the overnight shipping.
    I am having the same problem with only the left channel active through the earphones, so I might be returning mine soon.
    01-05-2015 11:01 AM
  1. Replies: 4
    Last Post: 01-03-2015, 07:49 AM
  2. wifi problem
    By Junaid A Khan in forum Samsung Galaxy S4
    Last Post: 01-01-2015, 06:57 AM
  3. Can I get some help syncing my calendar?
    By YossiN in forum General Help and How To
    Last Post: 12-31-2014, 01:14 PM
  4. Perfect Keyboard problem with android 5
    By BrainIcon in forum Android Apps
    Last Post: 12-31-2014, 01:22 AM
  5. Why is my Samsung Galaxy S4 screen acting so erratically?
    By Um Qasim in forum Ask a Question
    Last Post: 12-30-2014, 11:49 PM
