1. warren p1's Avatar
    Hi,
    I have a galaxy s5 and it is rooted (was rooted when I got it). I notice that the battery was draining faster than usual, so I decided to buy a new battery. The problem is that the battery has the same behavior, you can't go 10 hours without having to recharge the phone and this is without heavy usage: pretty much just messaging, calls and email. I see that the porcess that is consuming the battery is the gpsd service but I have the gps disable.
    Any ideas on what I can do?
    Why is my Galaxy S5 battery draining way too quickly?-screenshot_2015-01-08-17-21-08.jpg
    Why is my Galaxy S5 battery draining way too quickly?-screenshot_2015-01-08-17-21-14.jpg
    01-08-2015 06:29 PM
  2. Rukbat's Avatar
    That's normally caused by some app running in the background that's requesting accurate location information. See what's running in the background, kill it and see if gpsd stops being "tickled" so much. If it's an app you don't use, and you can't keep it from rerunning after you kill it, uninstall it. (gpsd itself draws virtually no power.)
    warren p1 likes this.
    01-08-2015 06:44 PM
  3. AZgl1500's Avatar
    Agree.
    A simple Restart can take care of that sometimes, but you mentioned changing the battery so that did a hard boot.
    01-08-2015 09:46 PM
  4. warren p1's Avatar
    I have restarted the phone, erase it to factory setting, disable syncing,.... but the problem persists
    01-08-2015 10:46 PM
  5. AZgl1500's Avatar
    Okay, let's try this test for tonight.
    pull down Notification panel and turn OFF both WiFi and MobileData.
    let that cruise for the night.... if it is an app that is trying to talk to the internet, that will stop it in its' tracks.
    I use MacroDroid to do this as standard protocol on my phone, see my signature.
    Attached Thumbnails Why is my Galaxy S5 battery draining way too quickly?-2-days-18-hrs-battery-64-.jpg
    01-08-2015 11:00 PM
  1. How to turn action memos into text?
    By logik brooklyn in forum Samsung Galaxy Note 4
    Last Post: 02-25-2016, 04:20 PM
  2. Upside Down to Wear on Right Wrist?
    By coreyacole in forum Moto 360
    Last Post: 01-05-2016, 12:33 AM
  3. Replacing Rezound Battery
    By daniel-k in forum Verizon HTC Rezound
    Last Post: 01-09-2015, 10:45 PM
  4. Moving Google messenger to top of list
    By Sam12Ash in forum Legacy Android & Other OS's
    Last Post: 01-08-2015, 06:34 PM
  5. Replies: 1
    Last Post: 01-08-2015, 03:09 PM
