1. Austin Spiller's Avatar
    Been dealing with this since April 11th 2014. I'm so mad that att galaxy s4 got the 4.4.4 but the galaxy s5 still is on 4.4.2.
    Attached Thumbnails kitkat 4.4.2 battery drain...-screenshot_2015-01-15-17-41-33.jpg
    01-15-2015 04:45 PM
  2. Rukbat's Avatar
    Press the graph and you'll get another screen. We need to see that one. It's not 4.4.2 itself - my Note 3 is still on 4.4.2 and I'm still getting over 2 days with minimal usage, at least a whole day with normal usage. (A weak 2G signal can kill your battery quickly, so can a few other things, which is why we need to see the next page.)
    01-15-2015 05:01 PM
  3. Austin Spiller's Avatar
    Here it is for today
    Attached Thumbnails kitkat 4.4.2 battery drain...-screenshot_2015-01-16-08-51-26.jpg   kitkat 4.4.2 battery drain...-screenshot_2015-01-16-08-51-17.jpg
    01-16-2015 07:52 AM
  4. Ichi_Bear's Avatar
    I tend to have pretty good battery life on my S5 on KitKat. Especially on standby. My you have a rogue app that keeps waking the phone up or excessively syncing in the background. Check your apps
    01-16-2015 01:20 PM
  5. AZgl1500's Avatar
    You have a rogue app eating up the power, there is nothing inherent in the S5 to use that much power.
    This is an example of an S5 that has been idling for almost 9 days, and it still has 37% battery.
    This is my wife's phone, it is only used to talk to our kids.
    01-16-2015 01:33 PM
  6. Austin Spiller's Avatar
    Yours is so much better bc Verizon sent out kitkat 4.4.4, att s5 is still on 4.4.2. The galaxy S4 on att has 4.4.4, and it used to have the same problem before when it ran 4.4.2
    01-16-2015 02:58 PM
  7. AZgl1500's Avatar
    Ah, but when my phone had 4.4.2 on it, I still got this kind of battery life........
    Because I use MacroDroid to control the internet.
    Stop the internet, and you will stop the battery mongering social apps.
    Here is my phone's typical battery screenshot.... I use my phone a lot, it is not just idle setting on the table like my wife's is.
    Attached Thumbnails kitkat 4.4.2 battery drain...-2-days-18-hrs-battery-64-.jpg
    01-16-2015 04:48 PM
  8. Jdroids's Avatar
    I also have S5 on at&t and my battery drain is nowhere near that bad. Seems you have some rogue app running and hurting standby drain. Your screen also shows some GPS activities awaking phone. I normally put location setting in power saving mode and switch to high accuracy only for maps, navigation.
    01-16-2015 05:00 PM
  9. Austin Spiller's Avatar
    How do I find out what app is draining it? It doesn't show up in the battery statistics
    01-18-2015 12:21 AM
  10. cardboard60's Avatar
    Do y'all ever clean up the history on your phones. And go into google or google chrome and pull down where it shows a where all you have been and delete that.
    And clean up your deleted mail.
    01-18-2015 09:27 PM
  1. Xiaomi battery 16000mAh
    By Rolon in forum Samsung Galaxy Note 3
    Last Post: 05-22-2015, 02:40 AM
  2. Inconsistent Battery Life
    By TJH132 in forum Moto 360
    Last Post: 04-13-2015, 12:07 PM
  3. Replies: 5
    Last Post: 02-10-2015, 02:55 AM
  4. Why is my LG g3 battery draining so quickly?
    Last Post: 01-19-2015, 05:11 PM
  5. What to do if App Starts Sucking Battery Life?
    By PowrDroid in forum Motorola Droid Turbo
    Last Post: 01-17-2015, 04:49 PM
