1. mzazthang's Avatar
    Has anyone else had this problem or now how to fix this??
    02-06-2015 03:58 PM
  2. Rukbat's Avatar
    Bring the phone to your carrier, tell them what happened (just what you posted here) and ask them to please redo the update for you, since it appears that the over the air update failed. (A lot of them do, because the Android update method is at least 10 years older than Android itself.)
    mzazthang likes this.
    02-06-2015 04:09 PM
  3. zippyzap23's Avatar
    I had this same problem. Today, it worked! What happened was, I received a text while my phone (Samsung Galaxy 5) was charging. The LED notification was blinking. Hurray! I then asked my husband to send a text while my phone wasn't charging. Still worked. Hope this helps!
    03-26-2015 08:47 PM
  4. BR34KF4ST's Avatar
    my LED switches off only when i andwer a whatsapp text when i am charging i have to on the screen and off it to make it work again other wise its working well
    03-28-2015 04:11 AM
  5. Mojave's Avatar
    I've been using an app called Light Flow. Used it on my S5 (Verizon) using KitKat 4.4.4. No issues. Now on Lollipop and Light Flow is working great....no issues. My LED notification light will blink with what ever LED color I have choosen. All I can say is....thank goodness it still works.
    03-28-2015 08:56 AM
  6. jaleelhamid's Avatar
    When I have my phone on Silent nothing works not even LED I need to increase battery for it to work. I just got the lollipop 5.0 update
    03-28-2015 11:18 PM
  7. jaleelhamid's Avatar
    But Light flow doesn't work when phone on silent
    03-28-2015 11:19 PM
  8. Mojave's Avatar
    I mute my S5 at night. I don't use my S5 for an alarm clock. I also have Light Flow set up with their "sleep settings". So no blinking LED after 11 PM. It will start blinking at 4AM. Had it set up this way on KitKat 4.4.4 and it stayed the same on Lollipop 5.0.
    03-29-2015 12:23 PM
  9. jaleelhamid's Avatar
    So how do I set up blinking on silent on lollipoo
    03-29-2015 11:43 PM
  10. LaRhonda Bates's Avatar
    I figured it out..hopefully its not too confusing....I have to have my phone on silent at work...so...your handset your up and down button on the side to choose to vibrate, ring or silent..put on vibrate ...after that go into your settings and find messages turn on to silent...after that your main screen will still show vibrate. However it will be silent and the blue light lights up again after any type of notification. .hope this is helpful.
    04-30-2015 12:14 AM
  11. Alan Wang2's Avatar
    i have this problem before , but when i restart the phone , then the problem have been solved
    05-04-2015 05:23 AM
  12. neighner's Avatar
    I tried what LaRhonda mentioned and that works but I hope someone can figure out how to make it work how it is supposed to.
    05-04-2015 04:41 PM
  1. Nexus 6 battery after one week
    By sdc1 in forum Google Nexus 6
    Last Post: 04-13-2015, 05:07 AM
  2. Sprint lolipop update. Got it yet?
    By Runnin_it in forum HTC One M8
    Last Post: 02-11-2015, 12:47 AM
  3. Replies: 4
    Last Post: 02-08-2015, 02:07 AM
  4. How to turn on notification light display?
    Last Post: 02-07-2015, 02:02 AM
  5. Replies: 1
    Last Post: 02-06-2015, 08:26 PM
