I am planning a trip to the UK and wanted your advice on using a phone in the UK. My Verizon S5 is stock and by the time we go I will have Lollipop installed (I have been delaying the upgrade).
As I understand my S5 is unlocked and is a world phone but of course the phone is CDMA and I believe UK uses GSM. Can I simply buy a sim card for my S5 and then it would work? Maybe you have other suggestions on the easiest way to use a phone in UK for a relatively short period of time.
Thanks for your advice.
