07-29-2016 03:21 PM
117 ... 345
tools
  1. Fleisz Iosif's Avatar
    I installed it almost 20 hours ago.maybe a new android update will help to improve battery life overnight,but now the only way to fix this problem is to put my phone every time to charge when its possibile and buy a power bank. Do you have battery drain overnight?
    08-23-2015 04:42 AM
  2. ironass's Avatar
    My money is on the user apps installed. Try putting your phone into Safe Mode tonight, as per #1.4 of S5 Lollipop Update Problems - Dummies Guide, and see if the drain persists.
    I am afraid you cannot compare your battery drain with that of a completely different phone, hardware and OS.
    08-23-2015 05:19 AM
  3. Fleisz Iosif's Avatar
    I will try it thank you.
    ironass likes this.
    08-23-2015 09:18 AM
  4. Bonnie Fechner's Avatar
    Hello there,
    Reboot the phone in safe mode first then update google play services.
    Wipe the cache partition and boot your phone.
    If the problem persist then a factory reset would fix it for sure.
    Posted via Samsung Galaxy S5
    I've done all these steps. Nothing has helped. Matter of fact yesterday my phone earse and reset itself. Went to go use it and the screen was on wizard setup. Samsung S5 is the worst phone ever. Makes me think twice in getting the Note 5.
    08-29-2015 05:42 PM
  5. Dan McTaggart's Avatar
    Android 5.1.1 Overheating Event
    Removed case and started turning off apps like crazy,then finally:
    WiFi Advanced Settings
    Always Allow Scanning
    Uncheck it
    10:49pm 41°C 4.1V
    10:50pm 39°C 4.1V
    10:51pm 38°C 4.1V
    10:51pm 37°C 4.0V
    10:56pm 36°C 4.1V
    11:01pm 36°C 4.1V
    11:07pm 36°C nominal 4.1V
    Device still warm - hunch
    Turn off Peel Remote (yellow icon)
    11:16pm 36°C 4.2V/4.3V
    11:19pm 35°C 4.2V
    11:26pm 36°C 4.2V
    11:29pm 36°C 4.1V/4.0V
    11:32pm 35:C 4.0V
    11:34pm 35°C 3.9V/4.0V
    Kudos to Power Battery 1.1.6
    Realtime Temperature / Voltage
    Dan McTaggart
    DCoolMusic.com
    Stay Cool
    10-22-2015 11:44 PM
  6. brackenmakay's Avatar
    Maybe the phone is not coping well with the update so try downgrading it back again and see if that helps. If it doesn't then try buying a new battery.
    10-23-2015 03:48 PM
  7. Terry Saul's Avatar
    I updated my Samsung Galaxy Alpha last night and had the same problems - battery draining at about 1% per minute and the phone getting much hotter than normal.
    Tried going through all sorts of options but nothing obvious.
    Decided to leave overnight from full charge and see what happened - 8 hours later was on 60% with a battery saver app installed that shuts off all wireless and stops running apps when not in use.
    As soon as I started using it again in the morning it got hot again.
    Tried enabling the 'Power Saving' option and allowed it to reduce the CPU performance. This immediately reduced the drain and the phone stopped getting hot. Not a great solution but to my surprise when I turned it back off again it did not start getting hot again and battery has only drained a further 15% in the 6 hours since.
    Not tried restarting to see if it goes back to getting hot again but looks like a promising possible solution for the Alpha.
    10-27-2015 11:40 AM
  8. Evan Mohr's Avatar
    Best thing to do is a hard reset.
    10-27-2015 03:05 PM
  9. JurgisP's Avatar
    Yes it is. But even using without SIM card does it.
    11-14-2015 05:34 AM
  10. mspm47's Avatar
    I am sick of DO A FACTORY RESET. How about better operating system upgrades?
    02-25-2016 03:24 PM
  11. brackenmakay's Avatar
    If you are doing a factory reset all of thee time it means that there is an underlying issue and you should contact Samsung about it as you may need a replacement.
    02-28-2016 04:43 PM
  12. misha613's Avatar
    How do I do a factory reset from an off phone since it is stuck in reboot loop?
    03-01-2016 06:56 AM
  13. misha613's Avatar
    Sorry, I have a Samsung Galaxy S5
    03-01-2016 06:58 AM
  14. Gina Manalo's Avatar
    Hi All
    I recently updating my Galaxy S5 to Android 5.0 (Lollipop) and since then have being having problems with the phone overheating and draining the battery. I fully charged the battery and within 2 1/2 hours the phone went from 100% battery life to 8% without me using it.
    The phone itself also became very hot to touch, both front and back.
    Has anybody else had the same experience?
    Thanks
    03-09-2016 06:09 AM
  15. BlurryEyed's Avatar
    As everyone else has said here Gina - Perform a factory reset on your phone.
    03-10-2016 05:13 PM
  16. CL B's Avatar
    Hi there forum-- Been reading that backup and factory reset and possibly downgrading to KitKat OS is the answer here. How do I find out which OS I have and if it is Lolipop, How do I downgrade back to KitKat? having overheating/ battery drain issues as well. thanks for any info.
    07-29-2016 01:59 PM
  17. ironass's Avatar
    Hello and welcome to Android Central CL B!
    Sorry to hear you are having problems. To determine your phone's OS, what it all means and how to download and flash firmware, see 42 Galaxy S5 models - Dummies Guide
    I would advise against downgrading your firmware as you will not get the latest bug and security fixes and your phone could be at risk. A Factory Data Reset might be a better idea and this is described in post #2 of S5 Update Problems - Dummies Guide. Before the Factory Data Reset I would suggest wiping the phone's cache partition as per #1.3 of the guideand see if that helps.
    07-29-2016 03:21 PM
117 ... 345
  1. Replies: 1
    Last Post: 12-01-2015, 06:09 PM
  2. Why is my battery draining really fast?
    Last Post: 04-14-2015, 03:51 PM
  3. Why isn't my Samsung Galaxy S5 reading my sim card anymore?
    By Valerie Schlotma in forum Samsung Galaxy S5
    Last Post: 02-13-2015, 10:04 AM
  4. Why galaxy tab s 10.5 is switching on?
    Last Post: 02-13-2015, 06:24 AM
  5. How do I stop my Galaxy Note 4 from going to the default ringtone?
    By Glenn Sager in forum General Help and How To
    Last Post: 02-13-2015, 03:44 AM
