07-29-2016 03:21 PM
117 123 ...
tools
  1. DC1967's Avatar
    Hi All
    I recently updating my Galaxy S5 to Android 5.0 (Lollipop) and since then have being having problems with the phone overheating and draining the battery. I fully charged the battery and within 2 1/2 hours the phone went from 100% battery life to 8% without me using it.
    The phone itself also became very hot to touch, both front and back.
    Has anybody else had the same experience?
    Thanks
    bunny0402 likes this.
    02-13-2015 04:45 AM
  2. Jay_burn's Avatar
    I'm having the same problem, I've just signed up and come to reply, and in doing so my phone is burning up and in watching my battery drop by 1% every three minutes...
    Bad times update, bad times.
    02-13-2015 05:05 AM
  3. Nabil Azarou's Avatar
    Hello there,
    Reboot the phone in safe mode first then update google play services.
    Wipe the cache partition and boot your phone.
    If the problem persist then a factory reset would fix it for sure.
    Posted via Samsung Galaxy S5
    ahj4513 likes this.
    02-13-2015 05:22 AM
  4. DC1967's Avatar
    Proving quite tricky at the moment, phone plugged into charger and showing the charge indicator at 0%. Phone now just totally died even though plugged into charger. Screen very hot.
    After a total of 3 hours after removing from charger this morning at 100% charged, the phone is now dead.....
    Now charging again, I have emailed Samsung Support to ask them to explain this, will be interesting to hear their none committal response.
    Why have they allowed the update without testing the OS correctly?
    Hassan272 likes this.
    02-13-2015 05:34 AM
  5. Nabil Azarou's Avatar
    Lollipop is working perfectly on S5, with a clean install you wouldn't encounter any problems.
    L_Tinaa likes this.
    02-13-2015 07:33 AM
  6. DC1967's Avatar
    Very Strange thinks happening since update. Phone now won't charge when plugged in to MacBook Pro, it used to, shows the charging symbol but battery life is falling with no usage.
    Looks like I'll have to back it up and do a factory reset.
    02-13-2015 07:38 AM
  7. DC1967's Avatar
    OK, so I decided to factory reset my Galaxy S5, a little drastic since I've had it for nearly 12 months.
    Backed up the phone to MacBook Pro through Kies, then did complete factory reset and recovery from Kies to reload APPS etc.
    Phone is now charging over USB through MAC and will keep you updated as to whether I still get the battery drain and over heating problem.
    02-13-2015 10:00 AM
  8. randomdude's Avatar
    i did the same thing with my galaxy that i've had for 3 months. made a world of difference.
    02-13-2015 10:16 AM
  9. iLogikk's Avatar
    Hello there,
    I tried this also but it didn't work. In fact, I did a factory reset right after the update to avoid any issues.
    In another post, someone mentioned that after unplugging his phone from the charger, he would wait about 5 mins and reboot it (he waited 5 mins bc doing it immediately after unplugging did not work and he had to do it a second time). This seemed to help the battery life be more stable. Today is my first day doing it and it has worked for me. I unplugged my phone at 7:20 am and it's still at 64% battery life which is still a bit low for the light use today but in days prior, I would be placing my phone on charger for its 3rd charge. I think there is some process running that is killing the battery.
    Also to note, while he didn't say this reboot helped the lag and lack of responsiveness of the phone, I have noticed it has helped me. Hopefully, this will be corrected.
    02-13-2015 12:02 PM
  10. DC1967's Avatar
    Finally received a response from Samsung which was pretty much what I expected.
    No admittance of responsibility for completely stuffing my Galaxy S5 but a useful walk through for factory resetting the phone.
    Thank you for your email. Your customer reference number is 211******3.
    I apologise for the issues you are facing with your Samsung device after performing software update, In regard to your query I recommend performing a factory data reset.
    A factory reset will erase all of the information stored on your device and will restore the software to original manufacturer settings. It will not remove software updates but it can undo any changes to settings that might be causing you problems.
    This process will erase all of your data so a full back up using Samsung KIES is strongly advised before conducting a factory reset.
    In order to back up your data, you will need to install KIES onto your PC. There are two versions of KIES: the one you need depends on what version of Android your Samsung device is using.
    To check the Android version of your device, please follow these steps:
    1. Go to your Apps
    2. Then to Settings
    3. Click on More
    4. Click About Device
    5. Here you will see your Android version
    If your Android version is 4.3 or above, you will need to download KIES 3. If your Android version is below 4.3, please download KIES.
    You can download both versions from this link: Samsung KIES
    Once the correct version is installed, please follow these steps:
    1. Connect your device to your computer using the Samsung USB Cable that came with your device (the charging cable with the plug head removed)
    2. Open KIES and click the Back Up/Restore tab.
    3. Click Data Backup
    4. Mark the check box next to the content you want to back up. You can select all content by marking the check box next to Select all Items. Click Backup.
    5. Click Complete when the backup is finished.
    6. You can have KIES automatically back up your device every time it’s connected by clicking the check box next to Automatically back up when USB connection is established.
    To factory reset the device please follow the next steps:
    1. From the Home Screen, tap the Applications menu item.
    2. Tap on Settings.
    3. Scroll down to Privacy and tap it.
    4. Tap the Factory Data Reset menu item.
    5. Tap the Reset phone button.
    6. Tap the Erase Everything button.
    Your phone will now reset and will begin the initial start-up process. Please ensure that you have your various accounts’ details ready – e.g., Samsung account, email account, Wi-Fi.
    If you have any more queries, please get in touch either by phone or email and I will be happy to help.
    Kind regards,
    Maneesha
    Customer Service Representative
    debdroid1a likes this.
    02-16-2015 06:12 PM
  11. Jay_burn's Avatar
    Has it helped though?
    02-17-2015 06:50 AM
  12. KJ78's Avatar
    Downgrade to Kit kat worked for me.
    CamCroz99 likes this.
    02-17-2015 12:40 PM
  13. BlurryEyed's Avatar
    Backup and Restore resolved my S5 overheating and lag. Loving lollipop now!
    Gray Area and Jonpato74 like this.
    02-17-2015 06:54 PM
  14. Jessop's Avatar
    Without being rooted how can I backup my entire phone, app, settings, messages, pictures everything phone logs etc....
    02-17-2015 08:50 PM
  15. coolada85's Avatar
    I had the same problem and did a factory reset without reinstalling the apps then put my apps in one at a time and found a few apps that started causing the problem again and deleted them. Hope this helps! It's been working great after that.
    Gray Area and Mpaige like this.
    02-27-2015 06:30 PM
  16. suewh's Avatar
    I have had my S5 for just over 6 months. After the lollipop update it was crashing, overheating and very quickly draining the battery. I tried one or two suggestions without success and then decided as a last resort to restore it to factory settings. Thankfully my Google contacts were saved automatically. I saved all my photos and videos to my computer. Since doing this everything is working very smoothly and quicker than before, I think my battery is lasting longer than it did originally, and my phone is no longer overheating. I would advise everyone out there to do a factory reset.
    BlurryEyed and Mpaige like this.
    03-05-2015 01:19 PM
  17. KJ78's Avatar
    Free up more storage. Move all possible apps to sd card along with pics, music, vids, etc. Delete apps you rarely use.
    03-05-2015 02:48 PM
  18. suewh's Avatar
    ***f a c t o r y r e s e t*** 👎
    BlurryEyed likes this.
    03-05-2015 03:37 PM
  19. sparkerc's Avatar
    I was having the same battery drain issue. Wiped cache.... no help. Factory reset... no help. Saw on another post about uninstalling Google Fit and then disabling the "S Health" app. I did both of those and it has made a WORLD of difference. mA battery drain was hovering in the 400-600mA draw. After the removal, I am sitting at about 160mA which is where I was at pre-Lollipop.
    YMMV but it is worth a shot and easy to do.
    03-05-2015 04:09 PM
  20. tracymcuk's Avatar
    I'm having the same problem with the phone getting hot and the battery draining, but it keeps getting stuck, it is so slow I feel like I'm on Dial up plus more.
    My question is if I do a factory reset will it go back to what it was prior to the DREADED UPDATE?
    Thanks
    04-02-2015 05:25 PM
  21. Umass021's Avatar
    Tracy if your on Verizon download the most recent update. It just came out and fixes these issues.
    04-02-2015 05:50 PM
  22. BlurryEyed's Avatar
    If you upgraded, a factory data reset will not restore your phone to Kit Kat. However, a lot of people report that after doing the FDR, their phone's were significantly improved.
    Verizon just recently pushed the latest update (which supposedly fixes the Over-heating and battery draining), have you tried updating that yet?
    04-03-2015 01:46 PM
  23. Uday3393's Avatar
    Hi All,
    My S5 has some mix problem , when i switch it on it will take 5 mins time to turn on which is very very slow .... always battery shows 100% .... if i dont use it will be on for 6-7 hrs and if i use wifi or call it will switch off in 3-4 hrs ... it never shows battery low .... i got software update of lollipop of 900+ mb when i try 2 download it shows failed ... when i reset phone still face same problem and one more thing when i put phone for charging phone gets heat ....try to do factory reset using volume upper key + power button + home button ... try to clear cache and factory reset nothing is helpfull ...
    can anyone help me ?
    04-06-2015 09:32 AM
  24. emcamp's Avatar
    My battery is very hot!! I've done a factory reset twice, dumped the dache multiple times and it is still the same.
    any other ideas?
    04-07-2015 04:46 PM
  25. BlurryEyed's Avatar
    Did you root it or modify in anyway? That behavior is very unusual. If that's how its behaving from the factory, I'd try to warranty it.
    04-07-2015 06:20 PM
117 123 ...
  1. Replies: 1
    Last Post: 12-01-2015, 06:09 PM
  2. Why is my battery draining really fast?
    Last Post: 04-14-2015, 03:51 PM
  3. Why isn't my Samsung Galaxy S5 reading my sim card anymore?
    By Valerie Schlotma in forum Samsung Galaxy S5
    Last Post: 02-13-2015, 10:04 AM
  4. Why galaxy tab s 10.5 is switching on?
    Last Post: 02-13-2015, 06:24 AM
  5. How do I stop my Galaxy Note 4 from going to the default ringtone?
    By Glenn Sager in forum General Help and How To
    Last Post: 02-13-2015, 03:44 AM
