1. Alejandro Najera's Avatar
    Hi i buy new Galaxy s5 mini unlocked LTE G800F!
    But i put my LTE sim card tha i get from Telcel 4G LTE and my phone only show 3G and H+ Network why?
    If i put the same sim card in my Blackberry 10 show 4GLTE but in galaxy s5 mini not...
    need to change the root for get LTE network or what? Please help me..
    I only use windows 8..
    02-18-2015 11:57 AM
  2. systemofadown1's Avatar
    Try going into settings, then more networks - from there select mobil e networks. Now select network mode & click on LTE.
    02-18-2015 01:21 PM
  3. Alejandro Najera's Avatar
    Well dont see LTE only 4G see my images i take screenshot
    Help!LTE network dont work in G800F :/ Galaxy S5 Mini-10997182_923336564385907_945500560_n_zpsd90e6561.jpg
    Help!LTE network dont work in G800F :/ Galaxy S5 Mini-11004789_923336121052618_837805933_n_zpse03b5cbd.jpg
    Help!LTE network dont work in G800F :/ Galaxy S5 Mini-11004791_923336421052588_1602338889_n_zpsb42b456e.jpg
    Help!LTE network dont work in G800F :/ Galaxy S5 Mini-11014739_923336274385936_1920859248_n_zps47012b68.jpg
    Help!LTE network dont work in G800F :/ Galaxy S5 Mini-11016492_923335937719303_1296086235_n_zps0e72d9ee.jpg
    I put and still show H+ HSPA!! but if i put my TELCEL LTE Sim card in my blackberry q10 show 4GLTE and work LTE network but in my galaxy s5 mini G800F dont work :/ :c
    02-18-2015 02:00 PM
  4. systemofadown1's Avatar
    I set my G900P to LTE/CDMA but LTE only comes up if the Signal is there & strong - otherwise it reverts to 3G. This might be your case. your phone might not have the correct band either _ just a guess...
    02-18-2015 03:04 PM
  5. Alejandro Najera's Avatar
    And how i can fix you know? :/ the sim is lte with others phones the sim work in lte network but in this phone not :/
    02-18-2015 03:52 PM
  6. systemofadown1's Avatar
    OK, first off where are you using your g900f? If it does not have the correct LTE radio bands for your area you won't be able to use it
    That's what its sounding like - your phone just can't access the 4g band you're trying to connect too.
    02-18-2015 03:57 PM
  7. Alejandro Najera's Avatar
    Well i use in Tijuana/Mexico but with other phone its work The LTE band and with this phone not i think the problem is the phone :/ only work with this phone 3G and H+ i dont know why... this phone is LTE is G800F
    In my area are LTE is Telcel 4G LTE..
    02-18-2015 04:09 PM
  8. systemofadown1's Avatar
    the problem is your phone may not be able to connect to that certain band of telcel 4G LTE while the other phone can. that is to say the other phone has the correct radios for that LTE band while the S5 does not have the correct radios and cannot pick up that LTE band.
    02-18-2015 04:14 PM
  9. Alejandro Najera's Avatar
    Oh i understand.. how can fix that?
    02-18-2015 04:16 PM
  10. systemofadown1's Avatar
    I think you won't be able to change this unless you get a phone that can connect to that band.
    if I were you I'd call my phone company to make absolutely certain that this is correct.
    02-18-2015 04:28 PM
  11. Alejandro Najera's Avatar
    my phone is ready root. If i put a custom root will work LTE?
    02-18-2015 05:02 PM
  12. systemofadown1's Avatar
    I don't believe that would help in this case
    A custom ROM can't change the hardware in your S5 mini.
    02-18-2015 05:07 PM
  13. Alejandro Najera's Avatar
    So cant fix my problem.. :/?
    02-18-2015 05:28 PM
  14. systemofadown1's Avatar
    It looks like you'd have to sell your S5 mini & purchase one that works on your carriers LTE network.
    That's why I'd give them a call, they should be able to tell you if your phone works on their LTE network & if not then what are your other options. I understand you want to use this S5 mini but I don't think its going to work on that LTE specific band
    02-18-2015 05:48 PM
  15. irak rodriguez1's Avatar
    The g800f lte works on b1, b3, b5, b7, b8 and b20 bands. Telcel 4g lte works on b4, so the s4 mini g800f its not compatible
    ironass likes this.
    06-16-2015 02:58 PM
  16. ironass's Avatar
    The G800F model is the worldwide version whilst the G900M is for South America and is designed for their networks. See...Samsung Galaxy S5 mini - Full phone specifications
    As stated by irak rodriguez1, the G900F is not compatible with the Telcel LTE network.
    06-16-2015 03:30 PM
  1. Help!LTE network dont work in G800F :/ Galaxy S5 Mini
    By Alejandro Najera in forum Samsung Galaxy S5 Mini
    Last Post: 02-18-2015, 11:10 PM
  2. Replies: 1
    Last Post: 02-18-2015, 12:13 PM
  3. issues with latest s5 update
    By Corrado Cattani1 in forum Ask a Question
    Last Post: 02-18-2015, 11:56 AM
  4. Does anyone have a ZTE Blade Q Mini?
    By Jong Lourney in forum Ask a Question
    Last Post: 02-18-2015, 11:54 AM
  5. Why won't my S5 (Lollipop) connect to Gear 2?
    Last Post: 02-18-2015, 11:10 AM
