1. rockitdog23's Avatar
    I'm all running 4.4.4 on my VZW S5 and am wondering if it's worth the headaches I've been hearing about and upgrade to 5.0 or just stay with what works (most of the time ). Any must have features on 5.0 that I don't have now?
    02-21-2015 12:16 PM
  2. systemofadown1's Avatar
    The big advantage of lollipop is Android runtime which you can open your developer options on 4.4.4 and run right now. A lot of people seem to have trouble out of the 5.0 lollipop for Verizon update.
    You can go ahead and download and install it and clear your cache and see if things aren't fine or just stick with 4.4.4 until the next bugfix comes out.
    02-21-2015 12:30 PM
  3. lgdlman's Avatar
    Just anticipate doing a factory reset. It works and clears any issues, battery life is actually better.
    systemofadown1 likes this.
    02-21-2015 01:22 PM
  4. geneod's Avatar
    Has 5.0 been pushed to your phone yet? I've heard rumors that you can only decline the update 3 times before it is forced on you. I have been specifically denying the 4.4.4 update on Verizon myself. I posted about this the other day but I have had only a couple of replies. You are exactly in the same situation that I asked about. Have you been able to deny 5.0 day after day? Thanks.
    02-21-2015 04:04 PM
  5. Rukbat's Avatar
    And, if you want to save yourself a few days, do a full data backup before doing a factory reset. (If you're running CWM or TWRP, back up the data partition, otherwise back up every app, all the app data, every picture, song, video, other file, launcher settings, etc., etc., and spend a day restoring the phone.)
    02-21-2015 04:07 PM
  6. mountainman's Avatar
    Not sure if factory reset clears the cache, but I would suggest doing that as well....
    02-21-2015 05:59 PM
  7. systemofadown1's Avatar
    a factory reset cleans everything
    02-21-2015 06:03 PM
  8. rockitdog23's Avatar
    It was pushed once and I selected no thanks instead of install now or install later. Hasn't come back again. It said when I'm ready to download just to do it manually.
    02-22-2015 09:13 AM
  9. Drummerboy1975's Avatar
    I spoke to a Samsung rep at Best Buy yesterday. Lollypop 5.0 is getting pulled and Lollypop 5.0.1 is coming out soon.
    02-22-2015 10:22 AM
  1. Replies: 1
    Last Post: 02-21-2015, 04:14 PM
  2. Replies: 2
    Last Post: 02-21-2015, 04:09 PM
  3. Why does Lollipop suck?
    Last Post: 02-21-2015, 02:22 PM
  4. Why won't my battery charge?
    Last Post: 02-21-2015, 01:09 PM
  5. Why is my S5 volume stuck on high during phone calls?
    Last Post: 02-21-2015, 11:59 AM
