1. Jdroids's Avatar
    My S5 has been excellent on stand by battery prior to 4.4.4 update a few weeks ago. It didn't matter much whether I keep WiFi radio on/off regardless of connecting to WiFi point. Now it seems like it's taking rapid drain if I leave WiFi on when it's not connected to any wifi points. It makes Android systems skyrocket on battery info page. I always had "smart network switching", "scanning always" off, so that's not the cause.
    Does anyone have similar issue with S5 on at&t? Did factory reset resolve it?
    02-23-2015 06:13 PM
  2. Rukbat's Avatar
    The phone is under warranty. Bring it to an AT&T Device Support Center and let them worry about it. (That's one reason many of us pay more to have AT&T - great service when we need it.)
    Just make sure everything is backed up - they may not want to waste their time, and they'll just give you a working phone.
    02-23-2015 06:44 PM
  3. steve Sharra's Avatar
    I use to get about 18 hours to 1 day on battery and now with 4.4.4 I get no more than 12-13 hours with screen on time with about 3-5 hours
    02-23-2015 09:42 PM
  4. Jdroids's Avatar
    Swapping the phone is the last thing I want to do because I believe my phone is fine hardware wise. I was looking to see if anyone with similar issue solved it through some software method.
    Still it's ok on battery drain if I remember to toggle WiFi off every time I leave my wifi connection area. But it's annoying as I didn't have to do this before 4.4.4
    02-24-2015 03:45 PM
  1. Replies: 20
    Last Post: 03-03-2015, 10:15 AM
  2. Why won't my AT&T Galaxy S5 Active send texts after U power saving?
    By Mike Thompson10 in forum Samsung Galaxy S5 Active
    Last Post: 02-26-2015, 12:20 AM
  3. LG G3 connecting with Mac 10.5.8
    By bobb22 in forum LG G3
    Last Post: 02-23-2015, 07:50 PM
  4. Replies: 2
    Last Post: 02-23-2015, 06:49 PM
  5. Why won't my Note 4 connect via USB at all?
    By FM2125 in forum Samsung Galaxy Note 4
    Last Post: 02-23-2015, 06:06 PM
