Save big + get 3 months free! Sign up for ExpressVPN today
  1. BR34KF4ST's Avatar
    everytime i try to connect to wifi it takes at least about 30 seconds but on KK it has quite fast is it me or everyone on lollipop having the same issue?
    (samsung galaxy s5)
    03-18-2015 10:34 PM
  2. Drunder40's Avatar
    Mine and my wifes works just like it did before 5.0. I read in a post in this forum there is a fix out that corrects that but only for the F version of the S5 which I believe is the unbranded European phone (Please correct me of that is not 100% accurate).
    Not sure when the US carriers will roll it out.
    03-19-2015 08:09 AM
  3. BR34KF4ST's Avatar
    do you have the link?
    03-19-2015 07:50 PM
  4. BR34KF4ST's Avatar
    anyone knows a solution? its bugging me that even s3 could connect to wifi faster
    03-20-2015 08:20 AM
  5. BR34KF4ST's Avatar
    help?
    03-22-2015 08:34 AM
  6. ricosuave14's Avatar
    after the lollipop update, my note 4 takes like 30 seconds to respond every time I look at the web page. It is frustrating to say the least. But it works fine over the air. It is just wifi that is slow. if anybody has an answer for this it would be appreciated!
    03-24-2015 07:36 PM
  7. ricosuave14's Avatar
    hi. My phone is working now with the wifi . I reset my router using the reset button. In addition I also temporarily removed WPA2 security and reset it again just to clear up any confusion the router may have w my phones update. I restarted security on the router. On my phone i had wifi forget the network. Then I reconnected to the network & manually entered my password to the network.
    in a nutshell, I had both the router and the phone forget each other to clear up any confusion from the lollipop update.
    hope this helps, happy Easter!
    04-05-2015 12:19 PM
  8. BR34KF4ST's Avatar
    defientely gonna try the reconnecting to wifi didnt understand the resetting of wifi tho
    04-05-2015 05:30 PM
  9. BR34KF4ST's Avatar
    just tried reconnecting wifi but wifi takes very long to boot up and quite fast to connect
    Attached Thumbnails slow wifi connection(lollipop)-screenshot_2015-04-06-06-32-57.jpg
    04-05-2015 05:34 PM
  10. BR34KF4ST's Avatar
    cant wifi connect any faster?
    04-14-2015 01:53 AM
  11. ironass's Avatar
    It sounds as though you are on an old version of Lollipop. The latest release, OC7, connects immediately. To check your model and firmware build, see #1.2, #1.8 and #1.9 of 40 Galaxy S5 models - Dummies Guide
    04-14-2015 04:24 AM
  12. BR34KF4ST's Avatar
    mine is sm-g900f
    04-14-2015 08:22 AM
  13. ironass's Avatar
    mine is sm-g900f
    That's the model of S5 you have but not which of the 200+ different, stock Samsung, Lollipop firmwares for the G900F that you have on it.
    04-14-2015 08:52 AM
  14. ricosuave14's Avatar
    Update: after a day or two, the problem came back. 😕
    04-21-2015 05:07 PM
  15. BR34KF4ST's Avatar
    apparently mine takes long to on but fast to connect
    04-23-2015 05:56 AM
  16. Bodeanicus's Avatar
    I was able to fix this on my router. Apparently, Lollipop doesn't like 5ghz and AES on some routers. I set the wireless security to WPA+WPA2, set the encryption to AES+TKIP, and set the frequency to 2.4ghz only (G.) Works correctly now. Good luck.
    10-12-2015 04:02 PM
  17. BR34KF4ST's Avatar
    yea my router has these 2 lights showing at 2.4ghz and 5ghz so and they are both lighted up
    10-12-2015 05:43 PM
  1. Anybody get the lollipop update?
    By ptm88 in forum Sony Xperia Z3
    Last Post: 04-15-2015, 02:19 PM
  2. S5 having issues after Lollipop
    By Sara Di in forum Legacy Android & Other OS's
    Last Post: 03-22-2015, 02:05 AM
  3. Moto G 4G Lollipop update and Sky Go
    By SASavva86 in forum Moto G
    Last Post: 03-19-2015, 10:59 AM
  4. Why does the wifi on my Note 4 keep turning on and off?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 03-18-2015, 08:36 PM
