how do I correct bright sunlight glare and of lcd on samsung S5 smart phone
W shooting video in bright sunlight the LCD screen on Samsung S5 smart phone blocks out the screen from the clare. How do I correct that to have a clear LCD to look at.
Re: how do I correct bright sunlight glare and of lcd on samsung S5 smart phone
You can crank up the brightness to the max, and I believe the S5 camera still has the 'Outdoor visibility' option which makes things stand out even further. But if you still find glare an issue, your only solution would be to get an anti-glare protective film to place on top of your screen. Note that these usually add a matte feel to your screen and colors might seem a bit muted.
