1. AC Question's Avatar
    There's a blue LED light on my S5 that's been on constantly since yesterday. I had LiteFlow installed, but I uninstalled it because I've heard there are issues.
    I pulled the battery and I've restarted the phone. Nothing seems to make it go away. The light comes on as soon as i put the battery back in, before the phone is even turned on.
    It's driving me nuts! please help!
    Julia
    03-26-2015 09:19 AM
  2. UpTheDumper's Avatar
    Go to settings> display>led indicator.
    You must have an undead text, or email or missed call that was over looked. Good luck hope it helped!
    Posted from the commode, thanks to Samsung Galaxy S5a.
    03-26-2015 09:24 AM
  3. juliamcrowe's Avatar
    There are no active notifications either. No texts, email, missed calls,, Thanks though!
    03-26-2015 09:48 AM
  4. UpTheDumper's Avatar
    Did you uncheck them and out stayed on?
    You could download light flow from the app store, check and uncheck until your light goes off so you know what the problem is.
    03-26-2015 10:06 AM
  5. juliamcrowe's Avatar
    Thanks, I tried that - still nothing. In fact, when I test the LED selections the blue light stays on between the flashes of the other colours.
    03-26-2015 10:17 AM
  6. UpTheDumper's Avatar
    I'd call for a replacement lol.
    03-26-2015 10:23 AM
  7. juliamcrowe's Avatar
    I called Samsung and the best they could do was tell me to restart it in safe mode. Thanks for your help!
    03-26-2015 10:24 AM
  8. UpTheDumper's Avatar
    Call your carrier
    03-26-2015 10:30 AM
  9. fesuarez's Avatar
    Is your phone encrypted? I have the same issue.
    07-25-2015 03:53 AM
  10. hamid Warcraft's Avatar
    Did you find any solution ?
    I have the same problem
    04-14-2016 11:09 AM
  11. Air23breezy's Avatar
    There's nothing wrong just a voice mail or notification
    08-27-2016 10:49 PM
  12. CLIPER's Avatar
    I've had this issue for a month now. Few times it goes off when I do some things and shows a small "disabled" icon at the bottom.
    10-20-2016 02:42 PM
  13. asddf1's Avatar
    Julia
    I just had the same problem. A light blue LED was stuck on constantly for weeks. I just replaced the battery with a new one and once I turned the phone on, to my excitement, the LED was off!
    Hope this.helps albeit belated :/
    12-26-2016 04:41 AM
  14. Jenconx's Avatar
    Julia
    02-23-2017 01:51 AM
  1. The Galaxy S6 Edge Is Totally Beautiful—And Pointless
    By ilordvader in forum Samsung Galaxy S6 edge
    Last Post: 03-29-2015, 07:29 AM
  2. How can I get into my phone that won't take my thumb print?
    Last Post: 03-26-2015, 11:14 AM
  3. Can you explain my poor battery life?
    By bbmjack in forum Samsung Galaxy Note 4
    Last Post: 03-26-2015, 10:33 AM
  4. Replies: 1
    Last Post: 03-26-2015, 09:03 AM
  5. Replies: 1
    Last Post: 03-26-2015, 08:39 AM
