1. lgossin's Avatar
    Does anybody know how to turn off the power up sound on the S5? I prefer no noise when I start my phone (now if you could also get rid of the Verizon screen... but I know better)
    Thanks
    03-26-2015 03:37 PM
  2. Travo79's Avatar
    You can root your phone and disable both! If your not looking to go that route, then you can put your phone on vibrate, or silent before you turn it off and the boot up sound will not play when you start back up.
    03-26-2015 07:14 PM
  3. lgossin's Avatar
    I have tried shutting down the phone on vibrate and on mute, the Samsung power up sound still plays. Not going to root the phone, way beyond my need and skill level
    03-27-2015 01:10 PM
  4. Travo79's Avatar
    That is really odd. I'm using an S5 on Verizon just like you. Running 5.0 now, but putting the phone on vibrate or silent has always muted the boot sound for me on previous builds.
    03-28-2015 09:42 AM
  1. Replies: 27
    Last Post: 06-12-2015, 10:20 AM
  2. Is there a voice command to toggle settings on / off?
    Last Post: 04-03-2015, 01:31 AM
  3. Replies: 2
    Last Post: 03-27-2015, 01:44 PM
  4. Why can't I connect to the internet after factory reset on my Nexus 7?
    By AC Question in forum Google Nexus 7 Tablet (2012)
    Last Post: 03-26-2015, 11:55 PM
  5. Need Help- Why buy the Edge?
    By Floridadomer in forum Samsung Galaxy S6 edge
    Last Post: 03-26-2015, 06:21 PM
