1. Adthay's Avatar
    I like to use my phone until the battery dies but the phone goes into power saving when under 5% battery life and I can find no way to disable it in order to adjust brightness or use the light.
    04-09-2015 05:28 PM
  2. mstrblueskys's Avatar
    I'm pretty sure you can't. You'll notice your flash won't work either. It's one of those things that the phone companies want to make sure of - that you have a phone longer than you have the rest of the tools of the smartphone.
    04-09-2015 05:36 PM
  3. Adthay's Avatar
    That is my problem yes. There must be some way to get around that. I bought an android because I didn't want my phone telling me how to use it.
    04-10-2015 04:00 PM
  1. Upgraded from Sprint S5 to S6 Edge
    By atishc in forum Samsung Galaxy S6 edge
    Last Post: 04-11-2015, 08:45 PM
  2. Is my phone AT&T?
    By AndroidAmatuer in forum General Help and How To
    Last Post: 04-10-2015, 07:34 AM
  3. POP3 email - How to 'CC' in myself on replies
    By Dan_B1979 in forum Google Nexus 6
    Last Post: 04-10-2015, 04:00 AM
  4. Why are kernel and Android System draining my battery so fast?
    By halfbeing in forum Legacy Android & Other OS's
    Last Post: 04-09-2015, 05:40 PM
  5. Can you put in a class 10 sd card 64gb even thought it says up to 32 gb?
    Last Post: 04-09-2015, 05:00 PM
