1. aspiller1998's Avatar
    Hi all, here I have posted screens shots of my battery. So far so good, I'm getting the same screen time I did on 4.4.4. Does everything look good to your guys? Thanks!
    Attached Thumbnails Lollipop 5.0 battery AT&T-screenshot_2015-04-09-23-11-16.jpg   Lollipop 5.0 battery AT&T-screenshot_2015-04-09-23-11-21.jpg   Lollipop 5.0 battery AT&T-screenshot_2015-04-09-23-11-10.jpg
    04-09-2015 11:27 PM
  2. Shadowpdx's Avatar
    36 hours and no problems.....no overheating.....no drain
    04-10-2015 01:09 AM
  3. aspiller1998's Avatar
    Good
    04-10-2015 07:12 AM
  4. troshs's Avatar
    It looks to me as if the OP's phone has a lot of wake locks. What this means is that while the screen is off, the phone is waking itself up internally to run some apps. My suggestion would be to download something like Wakelock Detector to see what is causing the problem. If the battery life seems okay for your use, however, the best thing would be to leave well enough alone. 15 hours isn't bad.
    04-11-2015 04:49 PM
  5. belodion's Avatar
    Yes, your Android System reading is high, OP....that is probably related to the wakelocks. You could probably get even better screen-on time, and battery life in general, if you can fix those.
    It's also a good idea - though a nuisance - to avoid heavy discharges, and recharge at about 40% battery charge remaining.
    04-11-2015 05:35 PM
  6. aspiller1998's Avatar
    Ok umm yeah it's going down fast now and as you can see the awake bar is on a lot... how do I figure out what's causing this? I already did a factory reset and still having the issue.
    Attached Thumbnails Lollipop 5.0 battery AT&T-screenshot_2015-04-11-21-43-14.jpg   Lollipop 5.0 battery AT&T-screenshot_2015-04-11-21-43-20.jpg   Lollipop 5.0 battery AT&T-screenshot_2015-04-11-21-43-29.jpg
    04-11-2015 09:45 PM
  7. ryetronics's Avatar
    Following. Having the exact same issue.
    I've also noticed that since upgrading to Lollipop 5.0 on AT&T, it my phone is plugged in and charging and a notification pops up, the screen stays on indefinitely, even when locked, instead of turning off a few seconds after the notification.
    04-12-2015 10:16 AM
  8. aspiller1998's Avatar
    This is so frustrating. If I put my phone into safe mode it hardly wakes up at all. So it has to be an app? Right?? Idk, but it's so frustrating! I need help, suggestions, fixes??
    04-12-2015 10:19 AM
  9. ryetronics's Avatar
    I just tried this and have yet to see if it really makes a difference, but I thought this post could be related. FYI, disabling the Unified Daemon will kill your AccuWeather temp reading on the lock screen (if you use that).
    http://androidforums.com/threads/uni...attery.847288/
    04-14-2015 07:06 PM
  10. aspiller1998's Avatar
    I'll try it, I don't use it nor is it even running right now. But I don't care as long as it (hopefully) fixes it.
    04-14-2015 08:07 PM
  11. troshs's Avatar
    Hopefully that solution solved your problem... I just found out you have to be rooted to use Wakelock Detector. Ugh.
    04-15-2015 10:10 AM
  12. aspiller1998's Avatar
    Didn't work, still having the issue...
    04-15-2015 10:27 AM
  13. troshs's Avatar
    If you have any apps like Amazon, Instagram, Spotify, etc disable those to see if anything changes. Those tend to be the biggest wakelockers.
    04-15-2015 10:31 AM
  14. aspiller1998's Avatar
    Ok, I'll try
    04-15-2015 01:31 PM
  1. Massive battery drain from media controls
    By jalan94 in forum Moto 360
    Last Post: 04-21-2015, 08:30 AM
  2. How long does the battery last before being replaced?
    By AC Question in forum Hardware Hideaway
    Last Post: 04-19-2015, 03:40 AM
  3. Why won't my Sony Z Ultra GPE update/ factory reset at all?
    By AC Question in forum Sony Z Ultra Google Play edition
    Last Post: 04-18-2015, 08:06 AM
  4. How do I stop my S5 from power saving at 5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 04-10-2015, 02:07 AM
  5. How can I get my Do not disturb working?
    Last Post: 04-09-2015, 11:02 PM
