1. Bridey1's Avatar
    Just updated ( all the prompts made me feel like i had to) and already the white backgrounds are driving me nuts! I've googled for a solution and I know it is a common complaint but I can't find a solution which makes me concerned that there isn't one!
    Thank you.
    04-21-2015 02:17 PM
  2. ironass's Avatar
    Thank you.
    You will need to root your phone and install a custom ROM with a black background.
    04-21-2015 02:20 PM
  3. Tritonemusic's Avatar
    I set mine up to toggle from light to dark by triple-clicking the Home Key . Settings > Accessibility > Direct Access (On) > Negative Colors (enabled).
    It's not always ideal, but has come in handy on occasion.
    ironass and stickballkid like this.
    04-21-2015 02:53 PM
  1. Whitish spot on screen just appeared...
    By mvalenti1970 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 03-27-2021, 12:59 AM
  2. Replies: 2
    Last Post: 04-23-2015, 10:59 PM
