1. AC Question's Avatar
    Last night my phone started pushing buttons like crazy. Nothing I touches shows up but literally in 5 seconds it will take 10 screen shots and go through like 10 apps and pages. Ive done a hard reset and left my battery out overnight and still does the same. If I take the battery out ill get about 30 seconds where i can use my phone before going crazy. Any ideas? Was able to scan for viruses also and came up as none.
    04-28-2015 09:37 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Any strong electromagnetic sources nearby, like a big PC power supply, or a powerful speaker? That can sometimes cause phantom touches, but that should stop once you move it away.
    Try booting into Recovery and wiping the cache partition: http://support.t-mobile.com/docs/DOC-10404
    Brian_Blaire likes this.
    04-28-2015 11:48 AM
  1. "Ok Google" on my nexus 6 is going to crap!
    By CHILLYWILL_95831 in forum Google Nexus 6
    Last Post: 04-29-2015, 10:57 PM
  2. Replies: 1
    Last Post: 04-29-2015, 03:01 AM
  3. Replies: 1
    Last Post: 04-28-2015, 11:51 AM
  4. How can i re install s memo on my samsung galaxy s4?
    Last Post: 04-28-2015, 09:28 AM
  5. Why my samsung galaxy s4 get switched off suddenly?
    Last Post: 04-28-2015, 02:50 AM
