1. AC Question's Avatar
    I am constantly getting notifications that my phone is out of storage. The biggest storage eater is Miscellaneous files, but when I go in there the files listed do NOT add up to the 6.33GB it says is there. I do have quite a bit of pictures, because every time I put them on an SD card they get corrupted, so there goes that method of storage. I have used several different SD cards, formatted each one before use, etc. I have hardly any apps installed. I am getting really frustrated and tempted to ditch my Galaxy S5 in the toilet.
    micky short likes this.
    05-20-2015 12:56 AM
  2. Christopher Korzenowski's Avatar
    I am also running into this issue. I think it is from an unruly, wild app. What carrier do you have? I think there is a problem with my voice mail app from Verizon. There are hundreds of log files with XML information trying to access my accounts. Is this a bug or virus?
    I tried to connect my device to my computer, but I'm unable to offload files anymore. Please help.
    06-09-2015 09:33 AM
  3. thecomicbookandme's Avatar
    Try this, it may help.
    Open the phone app and dial
    *#9900#
    Press "delete dumpstate/logcat".
    Hit "ok".
    Scroll down to the bottom of the page and tap "exit".
    This should open up some storage space. Good luck. 👍
    06-09-2015 10:24 AM
  4. MauiTurtle's Avatar
    I have tried this and nothing changed. I have a Galaxy S5, never had this issue on my S3. I have a micro SD card, I've tried deleting files, pics, etc...to no avail.
    Now I have a software update and it says "No Available Space to Download".
    Does anyone have a real solution to this problem????
    08-21-2015 04:50 PM
  5. thecomicbookandme's Avatar
    #1 Go into settings, storage, and clear cached data by pressing and holding cached data indicator.
    #2 Go into settings, application manager, swipe to SD card and make sure all the boxes are checked.
    #3 Install and use application SD Maid.
    Delete old and unimportant emails.
    A screenshot of your storage setting, including SD storage, would help.
    Yea, heavy and a bottle of bread.
    08-21-2015 06:03 PM
  1. Replies: 1
    Last Post: 05-20-2015, 01:43 PM
  2. What is a Safe way to do a Factory rest before selling my phone
    By ilordvader in forum Samsung Galaxy S6 edge
    Last Post: 05-20-2015, 09:00 AM
  3. Replies: 1
    Last Post: 05-20-2015, 07:19 AM
  4. Replies: 1
    Last Post: 05-20-2015, 02:37 AM
  5. How can I find out what kind of device I have?
    By michelle cuevas in forum General Help and How To
    Last Post: 05-19-2015, 11:59 PM
