1. dmagikwand's Avatar
    GS5 4.4.4 or 5.0 doesn't matter which ROM or which player, or if live streaming, sd card or internal storage.
    Happens every 20-40 seconds on both music and audiobooks. This has been a hard to research issue I'm having and is more common with folks that have Galaxy Note 4's, but some GS5's and random GS6 and also few other companies. The only consistent workaround that we've found is keeping the screen on (dumb sounding, right?). You can download an app from the store that will keep your screen lit until you disable it (battery drainer of course) and this resolves the issue but is a far cry from an actual fix.
    More info if you care:
    http://forums.androidcentral.com/sam...ing-audio.html
    and to Google:
    https://code.google.com/p/android/is...sort=&id=95294
    Help would be appreciated but all I REALLY NEED TO KNOW is have you frequently experienced this problem or not, yes or no? Need to decide whether to keep working on it or trade in my otherwise perfect 5 for a refurb. I'll assume hardware and return if virtually nobody else with GS5 is getting the problem, but I don't want to give up my phone if the refurb has a high probability of doing the same thing.
    Thanks!
    05-23-2015 12:01 AM
  2. srkmagnus's Avatar
    This is the first time I've heard of this issue on the GS5. Hopefully you find a fix...I'll keep an eye out and post back if there's any information which may help.
    dmagikwand likes this.
    05-23-2015 12:31 AM
  3. Smtrekkers's Avatar
    Yes
    Sent from my SM-G900V using Tapatalk
    05-23-2015 05:06 AM
  4. ironass's Avatar
    NO.
    G900F international on OD3 Lollipop.build.
    05-23-2015 05:12 AM
  5. cydewaze's Avatar
    Nope! Good luck!
    05-23-2015 05:29 AM
  6. troshs's Avatar
    Yes. Usually right at the beginning of a song. It's regardless of what player I'm using.
    05-23-2015 07:38 AM
  7. jonheld's Avatar
    I get rare occasional dropouts. During a 5 hour trip I'll get 2 or 3, but that could be attributed to RF interference. Nothing like what you're talking about.
    05-23-2015 03:30 PM
  8. seymour butts's Avatar
    05-23-2015 04:59 PM
  9. DaveTheA's Avatar
    Yes...it happens perhaps twice on my 15 minute commute...
    05-23-2015 07:18 PM
  10. telrod11's Avatar
    Rarely. About what I got with my Iphone...
    05-24-2015 08:15 AM
  11. BobLad's Avatar
    No - I listen a lot, but never have had a drop-out
    05-24-2015 10:37 AM
  1. galaxy s6 camera is weird.
    By shaynd in forum Samsung Galaxy S6
    Last Post: 08-16-2016, 07:53 PM
  2. Replies: 2
    Last Post: 06-13-2015, 08:01 AM
  3. Next Launcher issue with system widget
    By THE POTZ in forum Samsung Galaxy S5
    Last Post: 05-23-2015, 09:31 AM
  4. why is my galaxy s4 messing up?
    By Abel Coignet in forum Ask a Question
    Last Post: 05-22-2015, 11:52 PM
  5. My Note 4 won't detect that the S Pen is attached, why is it doing this?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 05-22-2015, 10:55 PM
