1. here4kids's Avatar
    without ordering directly from Samsung, where do I get some that will work as designed? seems any replacement I've gotten charges at a trickle..... not the intended 1% per minute. sometimes it seems it's the cord, other times the wall plug. shouldn't be this hard!
    05-30-2015 04:47 PM
  2. Rukbat's Avatar
    Samsung chargers have the data pins shorted to indicate that the charge is coming from the wall, not a USB port. You can buy a replacement charger for a Samsung that's not made by Samsung, but that has the short, or if you can do tiny soldering, or work on a cable, you can do the modification yourself.
    Android Central sells the Samsung charger for $15. Samsung Micro-USB 2A Travel Charger - Android Chargers & Cables
    05-30-2015 05:09 PM
  1. Replies: 2
    Last Post: 06-23-2015, 06:29 PM
  2. Replies: 2
    Last Post: 05-30-2015, 06:53 PM
  3. Charger Cradle
    By marki86 in forum LG G3
    Last Post: 05-30-2015, 04:27 PM
  4. Why 2 new lcd replacements don't work on my lg g3
    Last Post: 05-30-2015, 08:05 AM
  5. Why can't I connect my Note 4 or Tab 4 to my HDTV vial MHL cable?
    Last Post: 05-30-2015, 07:08 AM
