how to fix error ''check battery cover'' on s5 after update of lollipop. This option spear after every 5 minutes. Plz help to solve this issue.
Before update I also would get message to make sure charging cover was shut, that wasn't as bothersome and I just ignored it.
What is happening after Lollipop is that regardless if it is charging or not, it is constantly asking to check if battery cover (back cover) is on. It seems to not detect that the cover is on and I have tried with 2 different Samsung OEM cases.
I took it to my carrier who thought it might be the cover, changed the cover same issue. Curious part is that it only happened after ugprading to Lollipop...
So I call Samsung directly and mail it to them? The phone is still under warranty but I will be phone-less while they figure out the reason for this issue. That is why I was hoping it would get fixed with a future S/W release instead of having to mail out...
This is March 2016 and I can't believe this issue is still around after several years. I have only had the S5 Neo for 2 days and these random back cover warnings are popping up intermittently not just on reboot. I hate the smug people who say you should root your phone or that you can't blame Samsung for encouraging users to look after their phones. The issue has completely soured my customer experience and I will be tweeting about it after Easter. It shows that Samsung doesn't listen to its customers.
