I just bought my first smartphone , a Galaxy S5. While I new to smartphones, I am not new to tech. In my car ( a 2015 Subaru Forester) I was powering my S5 with the USB cable plugged into the car's USB port. I had the phone playing Pandora. I sort of assumed that I would get the music signal on the USB line but found that the enabled BT was overriding the USB so I was getting the music with my radio set to BT-A. The problem was that the every few seconds the volume would drop and the phone would make two beeps. If I disconnected the USB cable and ran off battery, this issue went away.
On further inspection, I noticed that on every volume drop with beeps, a USB connection notification was appearing in the notification lists. I just wanted the USB for power but it seemed to be trying to connect over and over and each time, the notification was interfering with the audio. I could not find a setting to stop the S5 from trying to connect to USB data.
Any ideas?
07-02-2015 11:33 PM
