1. Sir Gerald's Avatar
    My GS5 wont go to sleep whenever it is in its lock screen. This only happens when I get a notification. If I dont turn it off manually it will drain the phones battery until it dies. Any Suggestions ?
    07-04-2015 11:54 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to Settings>Developer Options​, and make sure Stay Awake is turned off.
    07-04-2015 06:30 PM
  3. Sir Gerald's Avatar
    Its always been off. Idk what else to do.
    07-05-2015 08:31 PM
  4. Mal Lignant Tumor's Avatar
    Clear the cache partition yet?
    07-05-2015 10:31 PM
  5. B. Diddy's Avatar
    That's a good idea: https://support.t-mobile.com/docs/DOC-10683
    Does this happen no matter what kind of notification it is?
    07-05-2015 10:34 PM
  6. Sir Gerald's Avatar
    Did that already, didnt work.
    And yes with all types of notifications.
    07-05-2015 11:36 PM
  7. Sir Gerald's Avatar
    Yess with all types.
    07-05-2015 11:42 PM
  8. B. Diddy's Avatar
    You could try reinstalling the firmware using Kies or Smart Switch. If you're unable to with those programs, try this method: http://forums.androidcentral.com/amb...interface.html
    07-06-2015 02:08 AM
  1. Replies: 2
    Last Post: 08-18-2015, 04:16 PM
  2. How can I get my message icon to show the amount of unread messages?
    By crystal_planet in forum General Help and How To
    Last Post: 07-06-2015, 06:41 AM
  3. What does SIM card is P UK- locked no service mean?
    Last Post: 07-04-2015, 10:31 AM
  4. "Active" Notifications with screen off?
    By Scott Unverzagt in forum Samsung Galaxy Note 4
    Last Post: 07-04-2015, 09:31 AM
  5. Replies: 0
    Last Post: 07-04-2015, 08:21 AM
