1. kiingy's Avatar
    So this just started happening about a week ago and its really annoying! My instagram and snapchat will not refresh or load at all enless I turn off my wifi and use my data. I've tryed restarting my phone and resetting it by taking out the battery and stuff but nothing works.
    So to make it clear the apps work while using Data but does not work when Im using my WiFi. And just last week I could use my WiFi for the apps and now i cant. I haven't updated my phone at all since then either.
    I really have no clue what to do and I would appreciate any help! Thanks
    07-10-2015 02:07 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen on any wi-fi network, or just your home one?
    07-10-2015 02:43 PM
  3. kiingy's Avatar
    Ok I dont think my last reply went through. So I said in the last message that I have yet to try any other wi-fi networks other than my own home wi-fi. So to answer your question, it is just my home one that is the problem.
    07-10-2015 04:16 PM
  4. B. Diddy's Avatar
    If you can try another wi-fi network, it would be helpful to narrow down the problem. Otherwise, see this guide for other tips: http://forums.androidcentral.com/amb...-problems.html
    Laura Knotek likes this.
    07-10-2015 11:55 PM
  5. Therygg's Avatar
    I have the same problem so does my brother. gmail won't update or give me notifications, Snapchat won't connect to server or give me notifications, and netflix won't connect also. I have a note 3 and have tested it on multiple wi fi's (school,work,home) however all these apps work when I am on 4g network.
    Edit: right when I was typing this gmail updated, netflix/snapchat still does not work.
    07-15-2015 03:39 AM
  6. Daniel Kawalsky's Avatar
    I am having the same issue and the answers is yes, it works on WiFi but my own house's.
    08-09-2015 01:21 AM
  7. The70th's Avatar
    Any updates or solutions for this? I'm having the same issue with my Belkin router and Galaxy Note 4...
    08-28-2015 10:23 PM
  8. Gaurav Pathania's Avatar
    same issue, it works with every other wifi i connect to but not with my home wifi :/
    09-19-2015 12:32 PM
  9. Jaspreet Singh16's Avatar
    I found the fix it worls for me try installing an app dns changer from playstore and select 1st dns server as google 8.8.8.8 and 2nd as google 8.8.8.4
    Bennallsopp1215 likes this.
    01-05-2016 08:42 AM
  10. Jaspreet Singh16's Avatar
    Try an app from playstore that is dns changer and use only google dns servers in it..
    01-05-2016 08:44 AM
  11. Bennallsopp1215's Avatar
    Okay so, you were right in the sense that the app worked however, is there a way to permanently configure my DNS settings in this way? I don't particularly want to be running a VPN on my phone just so I can use WhatsApp and Snapchat. Thanks
    01-28-2017 05:49 PM
  12. Gayle Lynn's Avatar
    Noticing IG seems to be playing with pinning my last post and having to pull down to refresh use to work.
    So I feel it is more about IG. What I do sometimes is turn wifi off/on, ot go in and delete the storage cache in the app. - Use to do that with Twitter too btw.
    01-28-2017 06:22 PM
  13. Bennallsopp1215's Avatar
    Clearing my cached data just doesn't seem to work. It's clearly an issue with my WiFi connection, because everything works fine whilst connected to a VPN.
    01-28-2017 06:36 PM
  14. sarahgad's Avatar
    Hey, may be you check the wifi router you are using at home. Secondly, a friend of mine was facing a similar issue, it was that snapchat or instagram did not refresh at all on mobile data or even wifi be it home or public. She got her phone software refreshed which then enabled her to use all apps quite conveniently.
    02-01-2017 01:57 AM
  15. nisalm's Avatar
    Disable QoS in your router. Read this : https://t.co/Y7OohI8jgn. Hope this helps
    B. Diddy likes this.
    11-13-2017 12:23 AM
  16. betsali04's Avatar
    home one...
    02-04-2018 10:20 AM
  17. B. Diddy's Avatar
    home one...
    Welcome to Android Central! Have you read through this thread yet? Try some of the solutions that have already been mentioned.
    02-04-2018 12:15 PM
  18. Jeslyn Tan's Avatar
    I have the same problem for instagram, snapchat and whatsapp after my phone underwent a software update! What should I do?
    05-11-2018 03:58 AM
  19. Mmcveigh344's Avatar
    Same
    04-10-2019 10:49 AM
  20. Ehunt97's Avatar
    I'm having the exact same problem! I have tried everything suggested- so annoying!
    04-10-2019 03:59 PM
  21. Rukbat's Avatar
    Necropost, but ...
    If nothing else works, try disabling mobile data when you want to use WiFi. An app (improperly written) to "choose" the "active" connection more than once, when there are two connections, can connect using one, then respond using the other - and since it hasn't connected using that second connection, the server ignores it. (You can't talk to a server until you've connected to it - those are two separate actions - and the IP addresses of your WiFi connection and your mobile data connections have to be different. [You can't be using the same "router" for WiFi that the carrier is using to get to the internet, and it's the connection that the router makes that sets the IP address that's sent to the server.])
    07-29-2019 03:14 PM
  1. Replies: 6
    Last Post: 07-13-2015, 02:05 AM
  2. Can I use my normal cell phone number to make wifi calls?
    Last Post: 07-10-2015, 04:17 PM
  3. Replies: 1
    Last Post: 07-10-2015, 03:03 PM
  4. Mopre on A3 Flipboard
    Last Post: 07-10-2015, 02:58 PM
  5. how can i turn on GPS from other phones
    Last Post: 07-10-2015, 02:57 PM
