1. AC Question's Avatar
    I recently paired Ankovo headphones to my Galaxy S5. It has resulted in a massive battery drain on my phone (I had to factory reset to get the drain to stop). Is this a known problem and is there anything I can do to keep these devices paired up, or do I need to cease use of wireless headphones?
    07-27-2015 05:12 PM
  2. GS5TR's Avatar
    Well.. If you use wireless bluetooth connection, with music on.. its not a small thing that your processor needs to run..
    07-29-2015 04:03 PM
  1. How do I mirror a Galaxy TabS 10.1 to a LG smart TV?
    By AC Question in forum Samsung Galaxy Tab S 10.5
    Last Post: 09-28-2015, 07:27 AM
  2. Replies: 0
    Last Post: 07-27-2015, 04:55 PM
  3. How to disable or undo clear all on lg g4?
    By daved31415 in forum Ask a Question
    Last Post: 07-27-2015, 04:51 PM
  4. Replies: 0
    Last Post: 07-27-2015, 04:40 PM
  5. Messages voice feature impossible to exit
    By kerguelen in forum Samsung Galaxy S6
    Last Post: 07-27-2015, 04:27 PM
