1. BR34KF4ST's Avatar
    after updating to lollipop,my wifi takes at least 15-30 seconds to connect to the wifi compared to kitkat which is instant in connecting anyone has solution to this problem?im on OE1 if that matters at any point
    08-05-2015 07:14 AM
  2. BR34KF4ST's Avatar
    help please?
    08-05-2015 11:32 AM
  3. BR34KF4ST's Avatar
    why does no one help?
    08-06-2015 02:22 AM
  4. kathy13xia's Avatar
    Apparently this is a known issue since lollipop update, I find lots of posts when I did a google search. One possible solution is to wipe the cache partition.
    08-06-2015 02:54 AM
  5. GS5TR's Avatar
    Did you take a look at your Wifi Settings on your Phone? Most of the time after updating to Lollipop, they are resetting the settings,
    Take a look, set some things on and off, Sure you will find something..
    08-06-2015 04:38 AM
  6. Rukbat's Avatar
    Try forgetting the connection, then connecting again.
    08-07-2015 07:12 PM
  7. BR34KF4ST's Avatar
    Well i downgraded to kitkat and the wifi connection was fast again thanks you all for your help
    08-08-2015 01:00 PM
  1. Replies: 9
    Last Post: 08-26-2015, 12:57 AM
  2. Can I get some help with a rooting problem in CM 11 for my Samsung sl i9003?
    By Akshay Kanth in forum General Help and How To
    Last Post: 08-05-2015, 04:15 AM
  3. Why does my HTC One M8 constantly turn of wifi?
    By AC Question in forum HTC One M8
    Last Post: 08-04-2015, 07:22 PM
  4. Can I get some help with a touch key light problem?
    By SteveFarrell in forum Samsung Galaxy S6
    Last Post: 08-04-2015, 12:23 PM
  5. Background Data and Sync problems....
    By elementz09 in forum HTC One M8
    Last Post: 08-04-2015, 12:19 PM
