1. AC Question's Avatar
    Just bought this phone on eBay, and i know nothing else other than that this problem occurs. I am not sure how the chargers are different, but doesn't power transfer through the micro-usb 2.0 port anyways and the other section is only for data transfer. If that is true then I believe it could be a cable issue.
    09-02-2015 10:11 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I think you're right, it's probably a problem with the cable. Can you try a different one? Bring it to your carrier store or a Samsung Store at Best Buy, and ask them if you can try charging it with one of their USB 3.0 cables.
    09-02-2015 10:48 PM
  1. Replies: 28
    Last Post: 09-11-2015, 02:48 PM
  2. Replies: 1
    Last Post: 09-02-2015, 11:19 PM
  3. How can I synchronizing my Phonebook with my car?
    Last Post: 09-02-2015, 11:15 PM
  4. Droid MAXX XT 1080. Where is the USB mass storage mode?
    Last Post: 09-02-2015, 11:06 PM
  5. Mystified & frustrated with sync problems!
    Last Post: 09-02-2015, 09:33 PM
