1. Jannukaz's Avatar
    Android 5.0, G900-F, cleared cache numerous times, already done a factory reset. Any help? Gsam shows dboxed_process 1 as using my battery. I can include battery screenshots if necessary.
    09-25-2015 03:01 AM
  2. BR34KF4ST's Avatar
    Add some pictures, it would help
    09-25-2015 03:29 AM
  3. Jannukaz's Avatar
    Ill add some when I get home.
    09-25-2015 03:32 AM
  4. Jannukaz's Avatar
    My phone loses 1% every 1-3 minutes when using + heat problems.-screenshot_2015-09-26-13-57-25.jpg
    My phone loses 1% every 1-3 minutes when using + heat problems.-screenshot_2015-09-26-13-44-24.jpg
    My phone loses 1% every 1-3 minutes when using + heat problems.-screenshot_2015-09-26-13-44-19.jpg
    My phone loses 1% every 1-3 minutes when using + heat problems.-screenshot_2015-09-26-13-29-01.jpg
    Sorry, i totally forgot about this thread, but, right now, i took my phone off the charger, and just browsing with chrome, and im st 94% already. My phone loses 1% every 1-3 minutes when using + heat problems.-screenshot_2015-10-01-10-33-28.jpg
    This isnt normal, is it? I man 6% for just 10 minutes..?
    10-01-2015 02:34 AM
  5. Jannukaz's Avatar
    And here it says : 3 hours remaining, is the s5 really only getting 3 hours with 100%? My phone loses 1% every 1-3 minutes when using + heat problems.-screenshot_2015-10-01-10-35-42.jpg
    10-01-2015 02:37 AM
  6. ironass's Avatar
    You have 3 of the biggest Top 10 Battery drainers installed. Try disabling FaceBook, Messenger and Spotify, charge to 100% and see how your battery and particularly Android System and Android OS, fairs after, say, 12 hours. See, also...
    Battery, memory, data hogs... top 10
    10-01-2015 02:45 AM
  1. Replies: 2
    Last Post: 11-17-2015, 09:27 PM
  2. Replies: 0
    Last Post: 09-25-2015, 02:42 AM
  3. Why my phone is stuck in boot up loop ?
    Last Post: 09-25-2015, 02:41 AM
  4. my galaxy 4 mini has suddenly stopped accepting e mails
    Last Post: 09-25-2015, 02:37 AM
  5. Is It illegal to upgrade AT&T Phones Manually
    By Kaustubh Yadav in forum Samsung Galaxy S4
    Last Post: 09-25-2015, 02:35 AM
