Save big + get 3 months free! Sign up for ExpressVPN today
11-06-2015 02:51 PM
30 12
tools
  1. B. Diddy's Avatar
    So does the battery look good?
    As I mentioned previously, your total screen-on time looks normal, so that aspect of battery life looks good. Idle battery life would be interesting to see, but that means you'd have to leave the phone alone for a while, and not use it as much.
    ironass likes this.
    11-06-2015 01:34 PM
  2. ironass's Avatar
    What does that have to do with the battery?
    Because your phone is new and may be struggling to download and update itself in the background, as I notice that you are on the Claro network and several Claro updates have been issued by Samsung over the last couple of weeks, for different locations and the answer to my question will tell me if this may be the case for you, or not. I am merely attempting to cover another possibility for your battery drain.
    MotherAyahuasca and B. Diddy like this.
    11-06-2015 01:40 PM
  3. MotherAyahuasca's Avatar
    Version
    Attached Thumbnails Switched to Android, does my battery look healthy? Please help-1446839349189.jpg
    11-06-2015 01:49 PM
  4. ironass's Avatar
    Version
    OK... the OJ1 firmware is indeed the most recent and is up-to-date for your model and CSC code, UUB. Scratch that theory!
    MotherAyahuasca likes this.
    11-06-2015 01:55 PM
  5. MotherAyahuasca's Avatar
    Thankyou guys for your help
    11-06-2015 02:51 PM
30 12
  1. Note 5 embarrassed me today - easy way to silence all?
    By 2ndHalfCor in forum Samsung Galaxy Note 5
    Last Post: 11-18-2015, 07:15 AM
  2. Cant connect to verizon hotspot from my Galaxy S5
    Last Post: 11-05-2015, 04:58 PM
  3. Is there anyway I can fix my phone? Galaxy S6 Active
    Last Post: 11-05-2015, 04:57 PM
  4. I need help retrieving my passcode
    Last Post: 11-05-2015, 04:44 PM
