1. AC Question's Avatar
    For some strange reason my phone wont charge it off and when it is off it flashes on and off with the lightning and battery size to charge meaning it takes forever to charge. 5 hours of charge off and its only on 50% and then the battery dies within 2 hours when switched back on. Super annoying. Does any one know if its the phone or just need of a new battery. Please Help, Would like to know before I take it to the shop and probably get charged an arm and a leg. Thanks
    12-17-2015 04:01 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! It could be the phone, the charger, the charging port, or the motherboard. First, try a different charging cable/plug. If that doesn't help, try a new or different battery. If that doesn't help, then you'll have to bring it to a repair shop or Samsung service center.
    ironass likes this.
    12-17-2015 05:42 PM
  3. dgcamero's Avatar
    Also, try vacuuming out your USB 3.0 port!
    B. Diddy likes this.
    12-27-2015 09:26 PM
  4. lynstks's Avatar
    I had the same problem a few months ago, and actually called Samsung support about it. They recommended a factory reset, which I had been trying to avoid -- but it fixed the problem for me.
    ironass likes this.
    12-30-2015 07:58 AM
  1. Replies: 2
    Last Post: 12-19-2015, 12:09 PM
  2. LG3 can not access the google store or display google photos?
    Last Post: 12-17-2015, 05:45 PM
  3. Replies: 1
    Last Post: 12-17-2015, 04:21 PM
  4. I do not know how to fix my Galaxy S4?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 12-17-2015, 03:37 PM
  5. Replies: 0
    Last Post: 12-17-2015, 03:11 PM
