I dropped my GS5 squarely on the screen side from about 24". Phone is protected by Otterbox Defender, so glass never touched pavement. Glass is NOT cracked. Display was dead. Power button and Home button bring phone to life as normal, but display is dead. I removed battery for a bit, then reinstalled battery (along with back cover), but same dead display. Phone vibrates on boot up as normal and lower lights are lit when they should. It seems the display is dead, BUT... if I gently place the battery in place and power up, I get a normal display, albeit a bit dim (but not exactly dim. I believe a color is missing, if that makes sense). If I apply pressure on the battery, the display gets normal, but if I continue pushing (all very gentle, no more than replacing the battery cover), the display goes dead again.
Is it possible that during the fall the battery pushed on something on the backside of the display (like a dead-blow hammer hitting the back of the display) which is causing the intermittent display issue?
Thank you in advance for any ideas...
