1. stevend122's Avatar
    Hi All...
    Can anyone tell me what the "D" symbol in the below image means/is?
    THANK YOU!!
    02-15-2016 09:09 PM
  2. nahoku's Avatar
    Probably some app you installed that begins with the letter "D". Check your running and downloaded apps to see if you can find something with a similar icon.
    02-15-2016 10:21 PM
  3. stevend122's Avatar
    Thanks...
    Would anyone happen to know what APP that may be then?
    02-15-2016 10:25 PM
  4. AXEL314's Avatar
    Thanks...
    What recent changes have you made to the phone? Have you taken Nahoku's advise and checked what apps you having running in the background? When you swipe down the notification bar, are there any alerts you can dismiss?
    Android Central App | S5 G900A kitkat root
    02-16-2016 02:34 AM
  5. prolongExistence's Avatar
    I just spent about a minute in the Play Store, looks like maybe Dubsmash?
    Feldon likes this.
    02-16-2016 02:57 AM
  6. stevend122's Avatar
    That definitely may be it. Could you (or anyone with a Galaxy S5 or S6) just download the app and run it in the background and see if that same logo pops up (screenshot whatever)?
    I am almost positive that's it but now I can't replicate it...???!!!! So annoying. And want to be 100% sure.
    THANKS
    02-16-2016 09:58 AM
  1. Replies: 8
    Last Post: 06-10-2016, 09:01 PM
  2. Clicking when plugging in Nexus 5X?
    By AC Question in forum Nexus 5X
    Last Post: 02-16-2016, 01:59 PM
  3. Replies: 1
    Last Post: 02-16-2016, 03:49 AM
  4. Flashlight for Samsung Galaxy Ace S765C
    By findoutman3 in forum Samsung Galaxy Ace
    Last Post: 02-15-2016, 10:47 PM
  5. Replies: 1
    Last Post: 02-15-2016, 08:20 PM
