So you limit the brightness? what app do you use? the problem isn't remotely visible if i turn the brightness up, what i wanted was an app to stop the display getting too DIM, especially when the phone idles and goes dim after 30 seconds, because then it's 5 times more visible.
The app i use is lux lite (app store) you can change put brightness on auto mode , but link a default brightness for whatever the ambient light is. For example, indoors the light might be dim, so you can either go into the lux dash and dim (or brighten it) and then link that brightness to the amount of ambient light. You can link the displays brightness depending on how much ambient light it senses basically. Curious to know what app you use??
Anyway I am going to attempt to replace the screen soon, as I found replacement kits on amazon for only 10 and it contains a suction cup to remove the screen, scalpel type tools to help you prize it off and adhesive strips, as you will be removing yours once you use a hot air dryer to soften then extract the screen from the body.
I have seen similar tutorials for the unibody phones, mainly iphone and htc , but they are a lot harder, and mean disassembling everything to access the screen.
Anyway i will post back here after i have done this to let you know how easy it was. If by accident i do damage the phone, i don't really care. as the new LG G5 will be out in march and features sd card and removable battery (i will never get a smartphone without both) i know they use cloud, but you can't access that if you lose internet and i know you can get up to 128 gig internal memory, but thats 5 times more expensive than buying a 128 gig memory card, the added bonus of the memory card being that it's removable and so versatile in it's functionality.
The removable battery because well, if you use your phone moderately/heavily and will find it difficult to sit near a charger for over an hour, then easily replacing the battery is essential, and much more convenient than carrying around bulky battery packs, which you then have to leave tethered to your phone while they work.
