1. schadbourne's Avatar
    I've had a notification that my phone is running out of storage space. I have an SD card in the phone, and the entire card is practically empty. My photos are being saved to a cloud system, I don't have any music on my phone, I have uninstalled almost every app possible and I'm still getting this storage space message. I don't know how to transfer data to the SD card. On my last phone I simply put the SD in and I was prompted to transfer data. That did not happen with this phone. I need a system update but there is no room! I have disabled apps that I'm unable to uninstall and I'm not sure what else I can do to fix this problem.
    02-23-2016 08:16 AM
  2. ironass's Avatar
    Hello and welcome to Android Central schadbourne!
    The first thing to check is your external SD card as there are loads of fake/clone cards flooding the web. Download, free from the Play Store, SD Insight, and check that your card is genuine.
    02-23-2016 09:38 AM
  3. jrijr's Avatar
    Following, because I have similar issues. I downloaded the SD Insight, and it tells me I have a Samsung 32 GB SD Card. I should be okay... so how do transfer to the SD card?
    02-23-2016 01:43 PM
  4. thecomicbookandme's Avatar
    Go to the my files app in the app drawer. Using the three dots in the upper right corner you can move files from device storage to the SD card. 😎
    Yea, heavy and a bottle of bread.
    02-23-2016 03:48 PM
  5. schadbourne's Avatar
    I went to "my files" and I clicked the three dots in the corner, but there is no option to transfer data.
    02-23-2016 03:55 PM
  6. schadbourne's Avatar
    I purchased the SD card at Best Buy. It is a Sandisk brand card. I am not able to download the app you suggested because of the storage space issues.
    02-23-2016 03:56 PM
  7. thecomicbookandme's Avatar
    It is fairly intuitive.
    Go to the my files app. Choose device storage. Press the three dots in the upper right corner and choose "select". Check the box of the file you want to move. Press the three dots again and choose "move".
    You will have to create a file on the SD card to move it to.
    02-23-2016 05:34 PM
  8. schadbourne's Avatar
    Thank you!
    02-23-2016 08:45 PM
  9. jrijr's Avatar
    This worked well for me. I may need to do a factory reset on my S5, and I have my photos, videos and contacts backed up on the SD card. Much appreciated for the tutorial!
    02-24-2016 08:22 AM
  10. VicLC2016's Avatar
    I am also having thus issue but not due to data that I can move to the SD card but due the high level of capacity used by the system and pre installed apps that keep getting bigger with every update particularly samsung text to speech engine and Google text to speech engine. I have to keep uninstalling updates and disabling those that will let me. I probably have around 4 GB max of my own downloaded apps and all music, photos, docs etc. Are on the SD card. I didn't seem to have such and issue on my S4 even though the internal memory is the same. Looking to maybe early upgrade to the S7. Will 32GB be enough with expandable memory for photos etc. ? S5 is 16 but in reality it is about 4!
    02-28-2016 03:28 AM
  1. Galaxy S4 Without answering caller can hear my conversation
    Last Post: 02-23-2016, 12:27 PM
  2. Replies: 1
    Last Post: 02-23-2016, 12:26 PM
  3. What is better: iPhone 5c Or Samsung Galaxy S6?
    Last Post: 02-23-2016, 08:46 AM
