1. animal lover1's Avatar
    Have had my Galaxy S5 for almost 2 years now and had never in my life put it close to water whatsoever. This morning I threw the sheets in the washer and after 15 minutes of not finding my phone I went to loook in the machine and there it was It was off and when I opened the OtterBox the screen was a bit wet. I took the back lid off and the battery and SIM card out and there was no visible water inside the phone at all. Proceeded to put it in a 2 lbs bag of rice and I plan to leave it there for at least 4 days. Any other things I might be able to do to save my phone? Any help or words of wisdom anyone can offer?
    thanks
    02-28-2016 08:20 AM
  2. srkmagnus's Avatar
    thanks
    Welcome to Android Central!
    You're best bet is to leave the phone off for a few days if possible. Let is fully dry - the rice will help draw the moisture out. Here's a great write-up on this topic with some help on what else to do: http://forums.androidcentral.com/amb...ml#post4158269
    animal lover1 likes this.
    02-28-2016 10:11 AM
  3. animal lover1's Avatar
    thank you. just read the whole thing... so I guess all that's left to do is just leave it and wait for the next 3-4 days
    02-28-2016 10:21 AM
  4. ironass's Avatar
    Looks as though you have done all the right things!
    What you should NEVER do with a wet/damp phone is turn it on... that's like turning on any other piece of wet electrical equipment.... it will fry it!
    Also, Never, ever, use a hairdryer on a wet/damp phone as this has the effect of driving the moisture further into the handset areas that may have previously been dry.
    Good luck and don't forget to offer up a prayer to the little green Android god before turning it back on.
    02-28-2016 11:18 AM
  5. larrykay's Avatar
    Post back and let us know how it went...
    02-28-2016 11:23 AM
  6. animal lover1's Avatar
    thanks everyone. yup would never turn on a wet electronic, don't wanna fry it. as soon as I had it in my hands I tore it apart and put all the pieces in 2 lbs of rice. will report back in 3 days to tell you all if the poor phone made it.
    02-28-2016 02:28 PM
  7. AXEL314's Avatar
    Sad to hear, good luck and keep us posted!
    Android Central App | S5 G900A kitkat root
    02-28-2016 04:02 PM
  8. L_Spilker's Avatar
    Damn.
    02-29-2016 01:36 AM
  1. Replies: 1
    Last Post: 02-28-2016, 10:22 PM
  2. Suggestions for a Tablet with a 16:9 Aspect Ratio?
    By aj00772 in forum General Help and How To
    Last Post: 02-28-2016, 10:16 PM
  3. Galaxy S5 OTG Support
    By SlackerMcFly in forum Samsung Galaxy S5
    Last Post: 02-28-2016, 07:55 PM
  4. Replies: 0
    Last Post: 02-28-2016, 07:46 AM
  5. Backup Samsung S5 to laptop?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 02-28-2016, 06:47 AM
