1. Netherscourge's Avatar
    I use a Pin Code to secure my phone.
    Whenever I lock or unlock my phone, it makes a "click" sound. I want to change that sound to something else, but there doesn't appear to be any options to do that.
    If I go to Settings -> Sounds and notifications -> Other Sounds, the only option is to Select or Deselect the "Screen lock sound". But there is no option to change what the sound actually is.
    I can change the lock/unlock sound if I don't have any passcode enabled, but I can't find an option to change it while using a passcode.
    Anyone have any ideas? I want my phone secured, but I also want to change that annoying click sound to something else.
    Thanks.
    03-30-2016 01:08 PM
  1. Replies: 2
    Last Post: 04-03-2016, 11:54 PM
  2. How to remove signature from email on Samsung Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-30-2016, 01:57 PM
  3. Can not connet to hot spot.
    Last Post: 03-30-2016, 12:53 PM
  4. Cannot unlock S4
    Last Post: 03-30-2016, 12:10 PM
  5. Replies: 0
    Last Post: 03-30-2016, 12:09 PM
