1. Double Tap's Avatar
    I recently purchased an unlocked S5 that was originally a T-Mobile phone. When I turn the phone on I receive a warning to check the battery door to help keep it water resistant. I also receive a warning when I remove the charger to close the door to the charging port.
    How can I prevent these from poping up?
    04-13-2016 03:18 PM
  2. AXEL314's Avatar
    The only way I know of is by rooting your device. I did that and used xposed to disable the warnings.
    Note 4 910C 5.1.1 | Android Central App
    04-13-2016 03:55 PM
  3. Double Tap's Avatar
    Thank you
    04-13-2016 04:28 PM
  1. Replies: 3
    Last Post: 05-08-2016, 01:17 AM
  2. Lg g5 battery
    By Sugarmoon88 in forum LG G5
    Last Post: 05-04-2016, 05:36 AM
  3. My phone won't switch or charge or light, why?
    Last Post: 04-13-2016, 06:19 PM
  4. Replies: 2
    Last Post: 04-13-2016, 02:11 PM
  5. Replies: 0
    Last Post: 04-13-2016, 01:42 PM
