1. James King15's Avatar
    I have just taken my phone out of my pocket to discover my phone has totally died apart from a constant green LED. i can take battery sim and SD card out. As soon as battery is placed in a power button press the Green LED comes on and doesn't go off. No vibration not sounds, nothing. i can plug the phone in without the battery inserted and get the same again when pressing the power button. Phone won't connect with Laptop either.
    04-17-2016 12:09 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try keeping it plugged into a wall outlet overnight undisturbed, then press and hold Power for 15-20 seconds to see if anything happens. If not, then you'll probably have to bring it to a repair shop or contact Samsung.
    04-17-2016 10:46 PM
  1. Replies: 6
    Last Post: 04-19-2016, 03:23 PM
  2. can external hard disk connet to samsung note 3?
    Last Post: 04-17-2016, 02:43 PM
  3. Replies: 2
    Last Post: 04-17-2016, 02:38 PM
  4. what is this app on the very top bar of my galaxy note?
    By tnm1234567 in forum Samsung Galaxy Note 4
    Last Post: 04-17-2016, 12:15 PM
  5. T-Mobile Galaxy Note Edge OS version
    Last Post: 04-17-2016, 11:46 AM
